Try the Fn key and F11 or F12 - that should turn up/down the volume on your Acer, depending on the model
Hope this helps - good luck!
I have the exact same issue . . . there was no sound coming from speaker.
Mostly this problem is happening in windows 10 and it happening after updating windows but sometimes it happens due to virus which corrupt drivers of laptop. Windows update install bad driver or corrupt driver also.You can get driver support from here
and fix your sound problem like i did,its my personal experience Get the best Asus Computer Support by Asus Support
Get Support from Asus for your volume or sound problem directly no need to wonder contact Online Technician for Asus devices here
You also have the volume control in the bottom right of the desktop taskbar. It looks like a speaker.
How to turn volume up/down without FN... i wanna use just F11 F12....Asus K50id
Hold Fn key and tap Page Up for vol up or Page Down for vol down works on most laptops. There will be a volume icon on two or more keys, if not the ones I mentioned, but you have to use the Fn key at the same time
You can turn up the volume by volume control key. it is available in your laptop key pad.
I had same problem with my asus laptop . i contact to asus tech support and they have fixed my problem. hope this will help you as well. for more information you can visit :
Tech Support For Asus
