Verify there is power to the electrical outlet. Make sure that a GFCI breaker has not tripped. Try unplugging it from the electrical outlet for about 5 minutes and plug it back in. Does this computer have a soft touch control panel? With the power disconnected remove the inner panel to reach the control panel board. Inspect the ribbon connector and make sure that the connector is fully inserted and has not slipped out. Check the ribbon connector for any signs of a short. My dishwaher was doing the same thing and it turned out the control panel ribbon connector had shorted across causing it not to work. If the contol panel tests good then lt could be a fuse located somewhere on the dishwasher or the computer board.
