Not unless you cut the wire and splice a new piece on, which I would not recommend. A new coil should cost you less than $20 and is not hard to replace. See the attached YouTube video on how to do it. https://www.youtube.com/watch?v=v6bQrNr4lv0
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
If you want a 'drop-in' replacement, you will HAVE to source a carb that was fitted as original equipment. Following the demise of Tecumseh's engine division, supply is limited to 'old stock', but there is fair spares aqvailability at present. A newer 'primer start' carb will fit, but you will have to remove all the choke operating mechanism. Don't fit a carb from a larger or smaller engine - the mixture will be wrong, and the engine will never run properly.
be careful, if the engine over revs it may just explode. These engines are very picky if over sped and easily blow up. Your problem may be a broken throttle control rod, have look at that first. If the control rods are fine and in place it could be the fly wheel governor is worn out.
