We have a KitchenAid KUDK03FTSS2 dishwasher but it is not cleaning the dishes. It gets hot and the water sprays, but the dishes still come out dirty. Any idea what is wrong?
Hi, I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
59iwsbf
Hi
If you
are noticing that the dishes are not clean, then there are a few things to
check for. Check the soap powder if it's kept in a dry environment. Also try
replacing the powder with something like a gel or liquid. Next thing to check
for is the water pressure and fill valve. Check if the water is filling in and
the spray arms are throwing the water with enough pressure. Try and listen to
the sound if you hear a proper spraying action sound.
If it
seems as a low water pressure then check the fill valve. Now, check if
dishwasher is draining the water or not. While the dishwasher is working check
whether the dishwasher is draining and there is not much left out water after
the cycle is complete. Try cleaning the spray arm with a soft brush. The water
temperature plays a major role in cleaning of dishes. The temp should be
between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
heatman101
zzty
