Freezers Logo
Alejandro Echanove Posted on Aug 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My unit is a Turbo Air commercial freezer model: TSF-49SD, only reach 30 F, the low pressure is 60 Psi, the high pressure is 240 Psi, fan condenser is ok , two fans inside are ok, coils clean, what's wrong
Dennis Boxerman
Level 3:
  • Turbo Air Master 1,306 Answers
  • Posted on Jul 27, 2021
Dennis Boxerman
Turbo Air Master
Level 3:
Answers
1306
Questions
Helped
647064
Points
2787
Since there is no mention of the refrigerant, and some models are now using R-290 (propane), it's hard to tell what these pressures represent. My suggestion is to remove the refrigerant and weigh in the exact amount the manufacturer requires. This eliminates alot of guess work and is usually the best place to start.
4 Related Answers
Anonymous
  • 828 Answers
  • Posted on Jul 29, 2008
SOURCE: turbo air freezer
Check the time setting on the defrost timer. It may not be set to the correct number of minutes for defrost. Compare it with the side that is working properly for the right time of the cycle.
Anonymous
  • 19 Answers
  • Posted on Apr 22, 2009
SOURCE: there is ice build up beneath commercial freezer
make sure you have the proper freon charge.
Dennis Boxerman
  • 1306 Answers
  • Posted on Jan 03, 2010
SOURCE: Turbo air TSF-49SD. I plugged in a used one that
http://www.turboairinc.com/TB-Service/Service.html
Go to this web site. Page down and your model number unit has a picture and service manual. I saw no "H1" error code in the manual. You may want to double check in case I over looked it. You can also call them for further assistance. Sorry I could not be of more help.
Anonymous
  • 6 Answers
  • Posted on Sep 22, 2010
SOURCE: looking at new freezer, what is the difference
Do you mean the MSF-23NM and the TSF-23SD? If so, you can find the information for them here:
http://www.turboairinc.com/TB-Products/Soliddoor.html
Basically, the difference between the two is that the MSF-23NM runs on more amps and is a new "maximum" series that Turbo Air came out with.
http://www.missionrs.com/MSF-23NM.html
http://www.missionrs.com/TSF-23SD.html
The product spec sheets at the two links above should be easy to download from our site. If you have any trouble, you can call us at 1(800)319-0690.
1helpful
My turbo air freezer iced in coil i unplug over night and i plug back and work normal about 3 to 4 day and then iced in coil again
Defrost element has had it or timer will not shut unit off, check both, if both ok, check thermo fuse.
Need any more help, email me at [email protected] or call me 08 9523 0552 West Australia.
DONT FORGET TO VOTE, I JUST SUPPLIED MY TIME FOR FREE. Hope you get it sorted. Regards Russ
Unit is off and will not come back have checked power source and it is ok.
does the compressor make any noise at all? If not, there is a control problem. If it does make noise I need further info and details. Let me know.
If we set the freezer to cut off at -10 next day it might cut off at -32 or it might just continue to run the compressor
definately sounds like a control problem. I'd start in that area first. Let me know what I can do for you. Just be sure to include the model and serial numbers and we will give it our best shot.
Msf-49nm freezer will not go below 34 degrees farenhight
Change the temp control,check to see if it is iced up on the evaporator
Temp. can not reach 0 degree.
things that need checking:
refrigerant level. Super heat. Condenser clean? Compressor effeciency.
These are things that an experienced tech can check. If you have some experience and gages/ tools, I can give you some things to do but most of this requires experience.
Let me know if I can be of any further help.
Defrost times and adjust
http://www.turboairinc.com/TB-Service/Service%20Manual%20%20-%20April%202008/TSF-49SD.pdf
go to this site and check out the service manual. I guessed at the unit you had as you did not include the model number.
You can also go to turboairinc.com and search for more info if you need to.
Hope this gets you your answer.
I have an electrical burn smell inside the 49sd, all seems to be working... just the smell that is stronger inside.
This is the web site for your manual for your unit. I've had some situations where some rubber type insulation has melted but I've not experienced any problem other than it makes a mess. Hope this helps.
Evap fans not turning on
If this is a commercial unit, you're too low on refrigerant (freon). Freezer should be about a minus 10 degrees for the evap and high side is ambient converted to a psi for the type of refrigerant that is in the system plus 25-30 psi.
The evap fans will not come on because the evap is not cold enough.
Hope this helps and good luck.
Apr 09, 2009 • Freezers
Looking for the white plastic clips that shelf hangs on.
Give Rick a call at Restaurant Parts and More. Turbo Air also makes Master-Bilt. Rick can probably get what you need. Just have the model and serial. He's good at this stuff. 1-888-814-1110.
Top Turbo Air Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
