Question about Turbo Air 23 cu. ft. / 651 liter Commercial Freezer MSF-23NM
Looking at new freezer, what is the difference between Turbo air TSF-23sdr and TSF-23nm? product specs would not download. thks
Posted by dutchcornerr on
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
Do you mean the MSF-23NM and the TSF-23SD? If so, you can find the information for them here:
http://www.turboairinc.com/TB-Products/Soliddoor.html
Basically, the difference between the two is that the MSF-23NM runs on more amps and is a new "maximum" series that Turbo Air came out with.
http://www.missionrs.com/MSF-23NM.html
http://www.missionrs.com/TSF-23SD.html
The product spec sheets at the two links above should be easy to download from our site. If you have any trouble, you can call us at 1(800)319-0690.
Posted on Sep 22, 2010
Turbo air m#TSF-72SD will not hold below freezing. Cleaned coil an temp dropped to 29 but no further...
If everything else is in proper working order, either a refrigerant level issue or and expansion device issue. If system constantly runs the previous, if not, possible temperature control. Look for system cycling or not cycling.
Jan 10, 2018 | Turbo Air Freezers
My turbo air freezer iced in coil i unplug over night and i plug back and work normal about 3 to 4 day and then iced in coil again
Defrost element has had it or timer will not shut unit off, check both, if both ok, check thermo fuse.
Need any more help, email me at [email protected] or call me 08 9523 0552 West Australia.
DONT FORGET TO VOTE, I JUST SUPPLIED MY TIME FOR FREE. Hope you get it sorted. Regards Russ
Mar 02, 2011 | Turbo Air 49 cu. ft. / 1388 liter...
Msf-49nm freezer will not go below 34 degrees farenhight
Change the temp control,check to see if it is iced up on the evaporator
Sep 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
My Freezer does not maintain the right temp. It wont maintain my food frozen.
The thermostat is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 17, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Is the Tubo Air TSF-49 a manual defrost and if so; can it be converted to auto defrost control?
it is automatic. If it is not going into the defrost mode, the defrost timer may not be working.
May 16, 2010 | Turbo Air 49 cu. ft. / 1388 liter Upright...
Looking for the white plastic clips that shelf hangs on.
Give Rick a call at Restaurant Parts and More. Turbo Air also makes Master-Bilt. Rick can probably get what you need. Just have the model and serial. He's good at this stuff. 1-888-814-1110.
Mar 21, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Freeze will not run doors heat nothing else
That is known as a puffed capacitor and usually indicates a power supply problem as well. The cap can be changed with a 50/50% chance to work again unless it took out other components.
Sep 14, 2007 | Turbo Air 72 cu. ft. / 2039 liter...
Turbo Air 23 cu. ft. / 651 liter Commercial Freezer MSF-23NM Logo
123 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
