Sewing Machines Logo
A
Ann von Brandis Posted on Jul 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Singer S/No. K9313999 - works with electric foot pedal & pedal on the ground which goes up and down (manual). It still has original manual, Singer box and some spares. How much it is worth?
tsalagi152
Level 2:
  • Expert 89 Answers
  • Posted on Aug 15, 2019
tsalagi152
Expert
Level 2:
Answers
89
Questions
Helped
21570
Points
178
Are you identifying the machine according to the serial number on the front of the machine? If y9ou have the manual, what model is it?
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Mar 30, 2008
SOURCE: Foot pedal
Your first port of call should be the Singer dealer from whom you bought the machine, it will be under warantee and you don't want to risk breaching the conditions by fiddling around yourself.
They have a duty of care to customers, and would be crazy to give poor service on a new machine.....phone them, outline the issues and arrange a time to meet with them (with the machine) to address the problems..perhaps they offer a familiarisation lesson, as many dealers do, that would also be of enormous benefit to you with a new machine and is a service we provide for all our customers to get them started, so they get maximum benefit from the beginning.
www.bargainbox.com.au
Anonymous
  • 27 Answers
  • Posted on Jan 10, 2009
SOURCE: Singer 1725
The hook drive gear is seized and requires lubricant ,this is the gear right behind your bobbin case I believe you can access it from the rear ,I hope this helps
Anonymous
  • 65 Answers
  • Posted on Apr 21, 2009
SOURCE: foot pedal not working
You can purchase that singer sewing machine foot control here:
http://www.sewingpartsdirect.com/foot-control-w-cord-singer-979314-031.aspx
Anonymous
  • Posted on Jun 01, 2010
SOURCE: just bought a used model singer 6233 need to know
The Singer 6233 was one of the models that briefly were made using air-powered foot controls. So you aren't looking for a traditional electrical connection. Instead, your pedal cord's female end will connect onto a black male nipple, that sticks out on the right side of the machine (the side with the handwheel). Just push it on until it feels snug.
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Jun 12, 2011
SOURCE: I have a Kenmore sewing
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
2answers
I have a singer Athena 2000 , it start working with out me touching the pedal. What can I do?
It sounds like your pedal might be stuck in the down position so it thinks your foot is on it. Unplug it, put some oil at the joints where the pedal goes up and down and work it up and down a little to get the oil into the joints. Then plug it in and see if it happens again. If it does, contact Singer customer service because you might have a defective pedal, but I don't think you'll need to after you oil it.
2answers
I have a Singer Athena 2000 that stops working randomly. I was able to start it again by turning the switch off and back on, but now it won't start.
Are you still having problems? If so try a different foot pedal. Make sure you use an original foot pedal for your singer. Just an idea.
3answers
Foot pedal does not operate needle
[PDF]INSTRUCTION MANUAL - Singer
www.singerco.com/uploads/download/445_4830_4832.pdf
around the sewing machine needle. ... ings of the machine and foot controller ... The spool does not turn. 7. ... Note: Do not operate machine without fabric.
2answers
Singer electric sewing machine 2 01-2 know it didn't work no electricity going in to sewing machine.Is there away I check the power cord and how do you put together the foot pedal
for workshop manuals go google and type in --workshop manual for singer sewing machine 2 01-2-- and download the pdf version page
take the power lead and foot control to a sewing machine repair shop ( anyone) and have it tested
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Need foot pedal control for singer 766
try calling or email these sites and ask them about the part
sewvacdoctor.com
a1sewingmachines.com
Where can I buy cable and foot pedal for Singer Serenade 10 sewing machine online?
Hi I need a foot pedal and power cable for Singer Serenade 30. Model 6235.Im In Jhb S.A.
2helpful
2answers
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
What is the proper way to thread a bobbin?
first go to singer website & check & see if they have a manual for the machine
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4016) & click search
here are some other websites to check for a manual
sewusa.com
the presser foot has a lever at the back of the machine or side which
lifts the presser foot, the needle move up & down when you press on the foot pedal.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
