20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine Questions & Answers
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas: Why does the electronic beeper beep and the sewing machine won sew Sewing... 20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
3/5/2018 5:44:02 PM • Singer 7467S... • Answered on Mar 05, 2018
7467S sewing machine beeps four time and won't let me sew
Hi! Probably too late to help the original asker, but I have this same machine and was having the exact same problem. 4 beep error message, but mine would not sew at all. Found this question through a google search, but no answer. But I figured it out! I had left the buttonhole lever down!! (Facepalm) I hope this is helpful to future googlers with a similar problem.
10/30/2014 1:24:11 AM • Singer 7467S... • Answered on Oct 30, 2014
Can I use a vintage singer 161103 zigzagger attachment on a 201 k machine?
No I don't think it will. That attachment is for a 'Slant Shank' machine like a 301. The K on the Sewing machine model number simply means it was built in Scotland. That means it is basically the same as most other 201's.
4/16/2024 5:14:24 PM • Singer Sewing... • Answered 2 days ago
Singer Futura CE 150. I bought a used carriage unit attachment for it and the it drags really hard. It won't move at all while on the machine or when I take it off. Is there a way to fix it? Thanks
Question edited for clarity. Do you mean the embroidery unit. If it is secondhand and has been stored for a long time, sewing machine oil, or worse WD40 goes 'gummy'. You would need to clean all the out. WD40 is a good solvent, so spray, leave it to soak, spray again and agitate with a brush. The wash it all off with hot soapy water. Dry thoroughly and after a few days, lubricate metal parts with sewing machine oil and any plastic parts with a dry silicone spray like Jigaloo. Test Jigaloo on a flat piece of plastic first as it is also a powerful fast drying solvent.
Embroidery Unit, Singer #052007
Sewing Parts Online https://www.sewingpartsonline.com > products > embroi... Guaranteed to fit Singer Sewing Machine Models: CE-150 Futura III, CE-250 Futura III, CE-350 Futura III, SES1000 Futura III, SES2000 Futura III. Free · ‎ In stock https://www.google.com/search?q=Singer+Futura+CE-150+carriage+unit ..
4/15/2024 12:19:18 AM • Singer Sewing... • Answered on Apr 15, 2024
Singer Curvy flashing lights
I cannot see a question. Please include a question.
3/21/2024 8:00:29 AM • Singer Sewing... • Answered on Mar 21, 2024
Free manual for singer 8618
check if machine is threaded properly
3/8/2024 10:31:28 AM • Singer Sewing... • Answered on Mar 08, 2024
I have a singer quantum stylist 9980. When I turn it on, it beeps as usual but does not do the needle adjustment. It will not sew at all. How do I fix that?
  1. In the event that your Vocalist Quantum Beautician 9980 isn't playing out the needle change and won't sew, there could be a few issues. To begin with, guarantee the machine is strung accurately, and the bobbin is appropriately embedded. Check in the event that the needle is embedded accurately and not harmed. On the off chance that the issue continues, counsel the client manual for investigating tips or consider reaching Artist client assistance for additional help.
2/12/2024 1:57:13 AM • Singer Sewing... • Answered on Feb 12, 2024
Error 20 while trying to zip zag stitch 7 on my Singer Futura
Lois, all questions need full 'make model (what it is) please. Futura is a range of models so ''Singer Futura' isn't specific enough. Add the model number after the word 'Futura' and press enter.. You can also look for the Service Manual. There is one in the link, but no Error 20. https://www.google.com/search?q=Singer+Futura+Error+20 ..
2/7/2024 4:40:48 AM • Singer Sewing... • Answered on Feb 07, 2024
2answers
Singer Touch and Sew 756 feed dog gear replacement
DON'T cut lumps out of your machine. There will be a sequence you use to remove the parts you need to access to the gears more easily. The Youtuber you referred to sounds like they have zero knowledge when it comes to these older style machines. 'Note' Some of the gear mount nuts are on a "Reverse" thread meaning you turn them the 'wrong' way to get them off. My limited knowledge is more on the much older hand crank and treadle machines. Try the Youtube link below for a channel called 'Andy Tube'. He has a good reputation for correct repair methods. The link is for a 758 but they're both Touch and Sew machines. You could also try the Facebook group 'Vintage Singer Sewing Machines' as they have loads of knowledge about loads of different machines. https://www.youtube.com/watch?v=zxd5hKjGBlE
1/29/2024 9:27:54 AM • Singer Sewing... • Answered on Jan 29, 2024
Singer 7467S Confidence Stylist Electric Sewing Machine Logo
Popular Tags
3 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
singer confience stylist beeps four time
  • Sewing Machines
