Nov 11, 2006 - My windshield wipers only work on high speed. ... If it's the compound switch on the lever on the steering wheel, it can be a bit complicated to ...
www.cargurus.com > Questions > Mercury > Grand Marquis
CarGurusMay 19, 2015 - Windshield wipers - My wipers stopped last week and the next day they ... slow or intermitt and only work on high speed and the washer wiper doesn;twork ... The LCM does not effect the operation of the motor or switch it just ...
www.fordflex.net > ... > General Ford Flex Discussions
Feb 16, 2011 - Windshield Wipers only working at highest setting ... rear wiper worksjust fine, just the front wipers only work at highest setting. ... the wipers sometimes grinds out the gears thus only working at high sppeds. If it is the motor or Transmission for the wipers, can I fix this myself and how much would it cost me.
? 3:23
https://www.youtube.com/watch?v=kc6e2Tmar68
Oct 25, 2010 - Uploaded by roadragecustoms
The windshield wipers only worked occasionally. ... My 1998 dodge ram wipers only work on high will this help me? thanks.... Express van. you have to take out the motor and the transmission from under the front of the van..
Check your charging system! That sounds like low voltage starvation. If a weak battery has a heavy load on it, such as a wiper motor, the electromechanical relay may drop out or "buzz," which interrupts the circuit at high speed, stopping the wiper because there is insufficient current available. You could simply have dirty (or corroded) battery connections!
Does it have the rain sensor (behind the mirror). Sometimes the rain sensor module comes loose.
Otherwise probably the wiper motor, which has the park limit switch in it, needs to be replaced.
Make sure wiper arms are tight they are on a spline also where the wiper arm transmissin conects to the wiper motor therw is a nut that holds a z shaped bracket that losens up and oblongs the rectangular slot so the wipers stop with the least resistance.
My 98 suburban did the same thing (has intermittent wipers I assume) I had to replace the wiper motor. AutoZone had a rebuilt one for $50. ($279 at dealer for a new one)
Most likely this is caused by something binding or water getting inside the motor,either way it is tripping the thermal overload inside the wiper motor.
