SOURCE: Black & Decker Grasshog GH600 lever replacement
this has been driving me crazy. try this pdf from the black and decker site http://support.blackanddecker.com/cgi-bin/blackanddecker.cfg/php/enduser/fattach_get.php?p_sid=98uDbvBj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=1885&p_created=1148586888&p_olh=0
SOURCE: how to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
SOURCE: I am tryinng to remove
These are REVERSE THREAD - this should do it - turn it the other way.
Gary @ Fix Ya
SOURCE: replacing the spool of string
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
is the drive cable between the engine and the head broken?
