No instuctions for my arctic twister which was given to me as is
This product wastes a lot of ice cream in its mechanisms. I would not reccomend its use to anyone who believes in "waste not..."
Here are the instructions for any wasteroos who would still use this product:
Série IC200 Series
Arctic Twister™
Ice Cream Mixer
? U.S.A./Canada 1-800-231-9786
Mexico 01-800-847-2309
www.blackanddecker.com
To Assemble the Ice Cream Mixer:
1. Insert the Twister firmly into the opening on the
Base (A).
2. Slide the Chute/Dispenser over the Twister along the runner
on the Base (B); it will click into place.
Note: Unit will not operate if Chute/Dispenser does not click
into place.
3. Hold the Lid with Ratchet Clip in one hand with the Handle
facing front. With one finger, push the Ratchet Clip on the Lid
forward. In other hand, hold the Plunger with smooth side
facing front, and from underside of Lid, insert Plunger into
Clip opening (C), pushing Plunger up until the Ratchet Clip
rests on top of the Plunger base.
4. Set aside the Lid with Plunger in place. Now you're ready to
start mixing up some fun and delicious ice cream treats!
To Use the Ice Cream Mixer:
• Assemble all ingredients before you begin to make your first
batch of twisty treats: Set out an ice cream scoop, the mix-ins
you plan to use, ice cream cones, cups or dessert dishes,
then bring out the ice cream.
• For best results, use hardened ice cream, frozen yogurt,
sorbet or sherbet directly from the freezer.
• You may want to rinse off the Lid, Plunger, Chute/Dispenser
and Twister before beginning new ice cream flavors or
mix-ins.
• Always wash Lid, Plunger, Chute/Dispenser and Twister
between batches, if you have been using ice cream or mix-ins
containing peanuts, to prevent accidental peanut
consumption by those who may be allergic to them.
1. Plug the Cord into a standard 120V wall outlet.
2. Position a flat-bottom cone, dessert dish or cup under the
spout of the Chute/Dispenser.
3. Place 1 scoop of store-bought ice cream into the
Chute/Dispenser. Sprinkle in 1-2 tablespoons of the mix-ins
(see "About Mix-Ins"); add another scoop of ice cream, and
continue layering as above, ending with ice cream, until
Chute is filled.
4. Fit the Lid with Ratchet Clip and Plunger in place (see
assembly instructions #3 above), onto Chute opening,
pressing down slightly and turning the Lid to the right to fit
into position, then to the left to lock it into place on the Chute.
5. Gently pump the Handle up and down a few times to "prime"
the Chute.
6. Press the On/Off Switch to "on" position, then slowly pump
the handle to move ingredients down the Chute. As you
pump the handle, the ingredients will automatically be moved
into the Twister, then out the spout of the Dispenser.
7. When the Chute is empty, turn On/Off Switch to "off" position.
Push the Ratchet Clip forward and pull up the Plunger, then
use the Handle to move the Lid to the right. Lift the lid with
the Plunger in place out of the Chute.
8. Repeat steps 2-6 to make as many batches as desired.
