How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
need to clear the memory on the fax machine i-sensys fax l100
Which memory? system? mobile ? RAm?
