disconnect
the line to the water dispenser at the water inlet valve on the back where the
water supply comes in and try the dispenser. if you hear the valve work but
water doesn't come out, the valve is bad. If you don't hear the valve, the
dispenser switch is bad. If water does come out
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
