HP Pavilion a1410n (ER890AA) PC Desktop Logo
Posted on Aug 14, 2009
Restoring windows shell common in my dell
Unable to save theme files to open with windows shell common, which would enable to save as a theme.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Aug 16, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
6198
Points
35
You should not download themes from an unknown site.If you are using windows XP then you can download themes from www.crystalxp.net.It is a very good site and you can download vista and windows 7 themes from there.
1helpful
2answers
Accidentally closed windows explorer process
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
Please follow these steps:
  1. Reboot your computer in the Safe mode with command prompt.
  2. Once Windows loaded, command prompt (black window) opens. Type notepad and press Enter.
  3. A notepad window opens. Type the following text into notepad:
  4. [Version]
  5. Signature="$Chicago$"
  6. Provider=Myantispyware.com
  7. [DefaultInstall]
  8. AddReg=regsec
  9. [regsec]
  10. HKCU, Software\Microsoft\Windows\CurrentVersion\Policies\System,DisableRegistryTools,0x00000020,0
  11. HKLM, Software\Microsoft\Windows NT\CurrentVersion\Winlogon,Shell,0x00000020,"Explorer.exe"
  12. Save this as fix.inf to your Desktop (remember to select Save as file type: All files in Notepad). Close Notepad.
  13. In the command prompt type Explorer.exe and Press Enter. Windows Explorer opens. Locate the fix.inf, click right button and select Install. Close Windows Explorer.
  14. In the command prompt type shutdown -r and press Enter. Your computer will be rebooted.
tip
Unable to run executable files (. Exe) on windows platform
It may happen that only executable files aren’t eager open properly: either you have the dialog box "Open With", it opens with notepad or another program.
This problem may be due to a error made on your PC. If this is not the case, then it is necessarily a virus, follow this tip to disinfect your PC.
To correct the problem, follow these steps:
First Solution This solution is valid for XP and 2000 versions.
  • Go to Control Panel and then Folder Options.
  • Select the File Type tab and then click New
  • Type in EXE file extension and click OK
  • The EXE extension is automatically selected, then click Restore
  • Close the dialog box
Second solution This solution works for all versions of Windows
  • Click on Start> All Programs> Accessories> Notepad
  • Select the text below> copy and paste it into Notepad
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\exefile]
"EditFlags"=hex:d8,07,00,00
@="Application"
[HKEY_CLASSES_ROOT\exefile\shell]
[HKEY_CLASSES_ROOT\exefile\shell\open]
"EditFlags"=hex:00,00,00,00
[HKEY_CLASSES_ROOT\exefile\shell\open\command]
@="\"%1\" %*"
[HKEY_CLASSES_ROOT\exefile\shellex]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\{86F19A00-42A0-1069-A2E9-08002B30¬309D}]
[HKEY_CLASSES_ROOT\exefile\DefaultIcon]
@="%1"
  • Then click on File> Save As ...
  • Select All files Type
  • Give a name for the file and add the. Reg
  • Click on Save
  • Close the notebook and then right-click the file. REG> Merge
  • Click YES and OK
on Jun 15, 2010 • Computers & Internet
I was able to download this zip file about a xp theme and i was able to unzip it already, but there's no executable file to istall my new theme. please help me.. thanks,...
Prepare Your Computer
  1. Because Micro$oft wants you buy everything from them, Windows XP wants theme files to be digitally signed. If they aren't then XP won't let you use the themes. You must first patch your uxthemes.dll file in your C:\Windows\System32 directory. This can be easily done using the Uxthemes Patch which you can download here. The patch supports Windows XP, SP1, SP2, XP 64 bit and Windows Server 2003. Run the patch, it will "fix" your uxtheme.dll file so you can use 3rd party visual styles. Disregard any warnings about files being changed, that is what we want to do. After you run the patch reboot your computer. Note: We recommend you create a restore point before running the patch just for good measure. We did not author this file we have used it our selves with no problems, use it at your own risk.
Install the XP Theme Files
  1. Themes are usually downloaded as a .zip file which must first be scanned using a virus scanning program, then unzipped to a temporary folder you can create on your desktop. Inside that folder you will most likely find a wallpaper image, .msstyles file, a .theme file and possibly a font file. it all depends on what the author has chosen to include in their theme package.
  2. If your theme package contains one or more font files (.ttf) copy them to your C:\Windows\Fonts\ folder.
  3. You may also find one or more .theme files (like axis.theme. Copy it/them to your C:\Windows\Resources\Themes\ folder. You will see a folder called Luna already in there, leave that alone, it is your existing Micro$oft XP Theme.
  4. Locate the .msstyles file, create a folder in the C:\Windows\Resources\Themes\ folder, I usually name it what the .msstyles file is named (like axis.msstyles so the folder would be axis).
  5. If you find a file called ShellStyle.dll, create a folder called Shell inside the first folder you created. Create another folder inside that called NormalColor. Copy ShellStyle.dll into the NormalColor folder.
  6. Most of the time you will unzip the file and everything will be properly ordered and only need to be copied to your C:\Windows\Resources\Themes\ folder.
  7. To install the wallpaper copy the wallpaper image file to your My Pictures folder.
How to Use the XP Theme
  1. While in your My Pictures folder that contains your wallpaper, click on the wallpaper file once to highlight it. In the menu on the left side of the window you will see at the top Picture Tasks. Click on Set as desktop background. You should see the wallpaper on your desktop.
  2. If the wallpaper needs to be stretched to fill the screen close the My Pictures window. Right click on the desktop, select Properties. The Display Properties window comes up, choose the Desktop tab. Your wallpaper should be highlighted in the list, using the Position box choose if you want it Tiled, Centered or Stretched.
  3. While in Display Properties if your theme had a .theme file select the Themes tab and select your theme from the list. If your theme only had a .msstyles file go to the Appearance tab and select your theme from the Windows and Buttons list.
  4. After you are done making your choices you can go to the Themes tab and save your theme by clicking Save As..., and then name it something.
  5. That's all there is to it and all without buying any programs.
1helpful
2answers
Dell inspiron 1420. No right click menu. May have been after turning off touchpad? in system tray.
Yes, it is a possibility. You can try visiting the Dell Support website and try updating the Touchpad driver. You will need a wired mouse for it though. Try restarting it first.
2helpful
2answers
Is their a program i can download to change my themes for windows 7 starter at first i couldnt change my wallpaper but then i found a program called OC and its possible so i wana know if someone created a...
Microsoft windows 7 has default 5 theme but Windows 7 beta 1 build 7000 onwards has several hidden & locked themes provided for regional countries such as Australia, Canada, Great Britain, United States and South Africa.Since these hidden themes are installed along with your Windows 7 installation you can unlock/unhide these hidden Windows 7 Themes for regional contries. Below are three deferent methods to get Windows 7 hidden themes.
Screenshot of Default Windows 7 Themeswindows-7-default-themes.jpg Method 1: Steps to Unlock & Unhide Windows 7 hidden locked Themes1. Unhide the Windows 7 System and Protected Operating System files from Windows explorer -> Organize -> Folder and Search Options -> view tab
2. Navigate to C:WindowsGlobalizationMCT.
3. Open a MCT-(AU, CA, GB, US, or ZA) folder for the regional theme that you want.
NOTE: AU, CA and ZA regions all have the same themes though.
4. Open the Theme folder in the selected region folder.
5. Select the .theme file to use it.
NOTE: Once you select a .theme file, Windows 7 will save it so that you will be able to change or select this theme again from within the normal Personalization window location.
6. Hide the Windows 7 System and Protected Operating System files.
7. Enjoy your new regional themes!!
Method 2: Using windows 7 Search (Simplest Method)1. Go to Windowswinsxs Directory
2. Search for *.theme.
winsxs-themes.jpg3. Double click themes with name in the format of XX to apply and save the theme.
Method 3: Registry Entry1. Open notepad and copy past the following lines
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionThemesInstalledThemesMCT]
“%windir%\Globalization\MCT\MCT-AU\Theme\AU.theme”=””
“%windir%\Globalization\MCT\MCT-CA\Theme\CA.theme”=””
“%windir%\Globalization\MCT\MCT-GB\Theme\GB.theme”=””
“%windir%\Globalization\MCT\MCT-US\Theme\US.theme”=””
“%windir%\Globalization\MCT\MCT-ZA\Theme\ZA.theme”=””
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerWallpapersKnownFoldersWindows WallpapersMergeFolders]
“%windir%\Globalization\MCT\MCT-AU\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-CA\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-GB\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-US\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-ZA\Wallpaper”=””
2. Save file as allregional.reg on desktop.
3. Double click on allregional.reg to add above registry entry.
4. Now you can access all Windows 7 Hidden & Locked Themes via right clicking on desktop and personalize settings.
We have created allregional.reg file for you, Download allregional.reg and run it on your machine and access hidden Windows 7 Themes instantly.
Screenshot of Unlocked – Unhide Windows 7 Hidden Themesunlock-unhide-windows-7-hidden-locked-regional-themes.png
My Dell laptop Recovery(D) is almost full. 418 MB free of 9.99 GB. It includes a file "MedicalD.bin" which I question.
Delete the Media.Bin file and check whether that gets the free space for u...the same file will not show u huge file size(infact its small),but causes this problem..Otherwise disable the System restore option and enable it...this will help in deleting the restore points which would actually occupy a lot of space and thats the reason why the D drive is FULL now...To disable and enable the system restore ..follow this link and follow the same steps to ENable it back again.
http://www.howtogeek.com/howto/windows-vista/disable-system-restore-in-windows-vista/
Installation problem
you need to download an unzip program i find that win zip for window works. also where are you getting your themes if you are not getting the from the windows website be careful the could have hidden thing in them. www.winzip.com is the website to get winzip which will unzip them for you so you can use them. there is a free trail on there for it.
2answers
Problem in applying theme
Hi, Try using theme manager. that should solve your problem. Here is a link for one you can try.
http://www.softpedia.com/get/Desktop-Enhancements/Themes/Theme-Manager.shtml
Cyborg
1helpful
7answers
XP Themes
i wanna full version themes for my desktops
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
