Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
I believe you have some sort of Dual display on your camera where you can view pictures on a TV. That might be the problem check your settings perhaps page 23 of the pdf manual above the display might have been bumped to off. Or perhaps the picture you took was really set to video mode on accident if you discover this is the case then check out playback mode on page 62. Try turning your dial to playback. Perhaps your pictures are on the internal memory.
Or if nothing is showing on the screen at all you might just have a faulty screen that went out and you'll find the service center info on page 101 good luck.
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost. Click Sony CCD Imager Support for details.
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
This sounds like CCD sensor is faulty and should be replaced . Camera works fine in playback mode generally with this problem but not in capture mode ( camera has gone 'blind'). Should be repaired free of charge if the camera is as old as you say.
its a zr 60 and it is in camera mode when it has a black screen
