Microwave Ovens Logo
Ellen Lamm Posted on Jun 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot turn off Kenmore microwave oven. control panel is not working at all. Is there a way to reset it?
David Emmel
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Jun 20, 2019
David Emmel
Expert
Level 2:
Sergeant:
Answers
295
Questions
Helped
128463
Points
781
Unplug it for 5 minutes then plug back in. No luck? Contact an authorized technician. Danger, high voltage inside
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Sep 12, 2006
SOURCE: Reset Microwave after a Power Outage
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 27, 2008
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 08, 2008
SOURCE: Whirlpool microwave/oven combo- model #RM288PXS
That would be a problem with your control board. It probably needs a few capacitors and a relay replaced and minor circuit board repair.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
P.S. (to Guest: Please make a new post with your model number. I think your problem is different.)
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 01, 2009
SOURCE: Control Panel of Maytag Microwave CMV 1000B doesn't work
You have a failed membrane keypad.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
[email protected]
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 11, 2009
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
Microwave Oven will not turn on
I may be able to help you or a friend troubleshoot it, but I would need the FCC ID number from the model tag to look it up.
FixYa doesn't always notify us of follow-ups, so feel free to contact me directly (see below).
It could be an issue with your control board, and I regularly repair these at an affordable cost.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Microwave oven kenmore 401.80086700 need to know how to acess the fuse in it
If this an over the range microwave, there should be a couple screws on the door side of the control panel that you remove and the control panel will drop down so you can access the inside of the microwave.
Kenmore microwave
If you jump power from the two ends of the fuse with a wire, does it work at all? Also, it may be that the control panel is just out, at least the display panel. If you open the door will the interior light turn on?
2answers
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Model # 80419: turntable and hood lamps inoperable
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
