So, you can use the user manual. You know, when I was choosing a vacuum cleaners Ecovacs Deebot N79 vs Eufy Robovac 11 on weselectedbest.com I have read their manuals and I made a decision judging by these manuals because it shows the attitude to a client.
It is fully explained in the user manual
Hi Shaun,
Check this out for your assistance:
https://www.youtube.com/watch?v=APigXCGfkLc
SOURCE: I need a Operate Manual
You can find your manual at the link below. Just click and it will open and you can download/print your manual:
http://www.irobot.com/images/consumer/cs/Roomba-owners-manual.pdf
I have a Eurolab and I can give you a couple of tips...
Spot = concentric circles from a start point and will continue for 4mins
Clean = will clean until battery runs out then go to base.
Max = will clean until battery runs out and then return to base, charge and go again.
If you interupt any of the settings you will need to manually return unit to charger (either by picking it up- or turning it off on the unit - then turning it on again while holding down "Max" on the unit). It will then find its way home. The two different settings on the seperate little room divider are about how big the doorway distance is ie 1 metre or 4-7 metres (somethinig like that) to prevent it going into a sep room. There is a little filter that needes to be cleaned 1 or twice a fortnight - just to help with suction. The auto settings on the charger unit should be self explainatory but I just set mine off in the morning while I am doing other things and haven't go around to setting it yet. I am very happy with mine and my floor has all of those loose bits gone. I empty the pod weekly.
You can't make it go back with the remote - or if you can it is not mentioned in the manual and I haven't worked it out yet.
I hope this helps.
Cheers
Brittany
SOURCE: instruction manual robotic vacuum cleaner M-488
go to www. retrevo.com or www. fitness.manualsonline.com
God bless you
SOURCE: How do robotic vacuum cleaners work?
I'm going to buy a robotic cleaner, but recently I've read an article about the difference between vacuum and mopping robots. It was mentioned that a floor mopping robot is better as it can clean all sorts of sticky grime, spills, and damp debris from the floor, and a vacuum robot leaves much of the grime untouched. Frankly speaking, I've started thinking about buying one of 5 Best Floor Mopping Robots of 2017 .
