Need full model number to determine specific part see link below. Instruction Manuals
SOURCE: need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
SOURCE: 1992 Reliance electric water heater model 501 has
Check the breaker and top thermostat and make sure they are not tripped. Move onto replacing elements if above is not the problem.
Turn water and power off to heater and attach a water hose to bottom of heater to drain down tank. May have to open hot side on a facuet to get it to drain.
Once drained remove elements with 1 1/2" found at local hardware stores. once elements removed and new ones in place. Turn water on and get the air out of the system. Once water is flowing from the hot side from all of facuet's in house.
Once all air is out now yaou are resady to turn power onto heater.
SOURCE: how do I change the
Buy elements at local hardware store or home center, like Lowes
Look at label on side of tank.
Label shows element wattage.
Element is also printed on end of element in tiny letters-numbers.
Typical elements are 4500 and 5500 watts.
Tank needs 10 gauge wire and 30 amp breaker for 5500 watt element.
Water heaters are fully repairable by homeowner.
1) Have you tested water heater to see if element is problem? You need cheap multi-meter from Home Depot.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) To change element
a) turn off power
b) drain water from drain valve ... once it starts draining, loosen element slightly while tank still has weight to hold against you turning element wrench.
Here's what to do if water heater won't drain:
http://waterheatertimer.org/Water-heater-will-not-drain.html
c) open covers on tank, remove element using element-wrench from hardware store or home center.
If element won't come out:
http://waterheatertimer.org/How-to-remove-old-water-heater-element.html
d) Clean out tank if needed.
e) Replace element.
f) Fill tank entirely with water before turning on power or element will burn out.
g) Once tank is filled, and water flows steady out of tub spout, turn on power.
Each steps above is shown on following link:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
3) You need to buy some things:
Screw-in type (not bolt-in type) Element that matches wattage on tank label. New Element comes with washer.
Inexpensive Element wrench.
Inexpensive multimeter if you are going to test parts first.
Some pieces of pipe and hose if tank sediment needs to be cleaned out.
Washing machine hose if tank will not drain (return after job is done).
4) Also:
You need flat tip and phillips screwdriver.
Lighting to work on tank
Some WD-40 if element is stuck in place.
Garden hose to drain tank.
Shop vac and duct tape if you need to vacuum out sediment.
Tarp to protect floor and carpet
Maybe a knife to cut back insulation on wire if wire is burned at element.
Web links above go through entire process step by step.
Add a comment if you need more help, I'll be back around 5 CST
SOURCE: Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Did you replace with the same heating elements? That's my guess if nothing else had been changed.
Check out this tip..
How to replace the Thermostat and Element for Electric Hot Water Heater
heatman101
