Hi there, this should help
no-maybe
so the software is made to run on mac and 2 you may be able to use something like boot camp and there is no kind of guarantee it would even work period and no way to check besides trying it. Good luck
https://www.honestech.com/main/AudioRecorder20Deluxe.asp
https://www.6ya.com/mr.mike
From their website
Question 1:
Can QuickVerse 2007 run on Windows Vista?
Answer:
Configure QuickVerse 2007 for Microsoft Vista Compatibility Mode
http://www.quickverse.com/Shopfiles/Faq.asp?ID=QV2007WIN
Browse to the Program Files folder for QuickVerse 2007
C:\Program Files\QuickVerse 2007\qv11.exe
C:\Program Files\QuickVerse 2007\QVBookManager.exe
SOURCE: audio device p5ad2-e deluxe with windows 7
This worked for me. You need the sound drivers for the "Intel C-Media High Definition
Audio CMi9880".
I went to this sight www.softwarepatch.pl/plikd.php
Its in a different language but click on the box.
i downloaded the audio file called UDAX008(Logo56.62).zip.
Click on the box, and downloaded the zip file.
Unzipped it.
Then change the compatibility mode of the Setup.exe file to Winxp Sp3 by going to the properties of the Setup.exe file and click on the Compatibility tab. Check the box for "Run this program in compatibility mode for". And change it to Windows XP Service pack 3.
The drivers are actually meant for windows xp but they are working fine for me and im very happy now. I was worried like you. I hope it works for you.
w w w . s o f t w a r e p a t c h . p l / p l i k d . p h p
SOURCE: is HP KQ246AA 8.0MP Deluxe Webcam compatible with
Hello and thank you for using Fixya's services.
Yes, the camera is compatible with Windows 7. You will need to download and install the new drivers from HP. You can find the drivers here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3737180&lc=en&cc=us&dlc=en&lang=en&cc=us
Be sure and download/install the drivers before plugging the camera in. This will guarantee a flawless install.
Hope this helps!
SOURCE: How can I make Windows 7 compatible with Dazzle DVD Recorder?
No... the only way is if Dazzle makes an upgrade or patch. Win7 is closing the door on Software that is not Certified for this specific OS. Good and Bad... mostly Good... for the long run...
You can contact Dazzle... they may discount or help if you are a loyal client :)
SOURCE: software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
