20 Most Recent
ASUS P5AD2-E Deluxe Motherboard Questions & Answers
Asus will not turn off after shutdown
All these things point to the bios. You need to go to the Asus site for that motherboard and download an upgraded bios. There will be directions there on how to update your bios, probably both from Windows and from the system prompt.
Cpu temp overhead
Clean the cooler on the top of the cpu.
If this not works...new cooling or change the thermal grease.
Get some cooler in the case to get a better airflow.
P5AD2E deluxe bios wont load even after i flashed
Sounds like your BIOS is corrupt. In general, the only recourse is to replace the CMOS IC outright. You
could remove the IC and reprogram it in a EEPROM programmer. Or you could swap it out with a
similar motherboard. Or you could contact Asus and order a replacement.
P5ad2-delux
This is because the sound driver achitecture does not fit with operating system of windows 7. Search for the a sound driver that will be compatible with windows 7, that will be found in the website of the motherboard brand.
Audio device p5ad2-e deluxe with windows 7
This worked for me. You need the sound drivers for the "Intel C-Media High Definition
Audio CMi9880".
I went to this sight www.softwarepatch.pl/plikd.php
Its in a different language but click on the box.
i downloaded the audio file called UDAX008(Logo56.62).zip.
Click on the box, and downloaded the zip file.
Unzipped it.
Then change the compatibility mode of the Setup.exe file to Winxp Sp3 by going to the properties of the Setup.exe file and click on the Compatibility tab. Check the box for "Run this program in compatibility mode for". And change it to Windows XP Service pack 3.
The drivers are actually meant for windows xp but they are working fine for me and im very happy now. I was worried like you. I hope it works for you.
w w w . s o f t w a r e p a t c h . p l / p l i k d . p h p
NOT SUPORT
the drivers may not be compatible with the mother board. Try goping to their website and get the correct driver.
Graphics Card for Asrock Conroe 1333-D667
i have intel pentium4 2.2ghz dualcore and dell monitor . just i installed but i dont have any drivers for that. now my display is not clear it shows different like colours in whater and it showing mixed colour screen what can i do for this how can i solve this problem and i dont have audio drivers also how can i approch and which way give me some website names for audiodrivers
What grapic card will set for AsRock 775i45gv
Any PCI-express x16 board will work. It all depends on your power supply & budget as to what card you want. Check the AMD/ATI website for a list & specs of their cards. Nvidea also makes great cards. You can research for other manufactures based on the ati or nvidea chipsets. Hope this helps & please remember to rate my answer. Thanks.
3 RAPID BEEBS ON AN
Normally 3 short beeps is MEMORY problem. Make sure the right memory is used and seated properly.
Graphics Card compatibility?
Hi.
I could tell you exactly what Graphics Adapter to buy, but
i think is better if you learn how to decide by yourself, so i recoommend you to use the following url, that will take you to your motherboard Specs( you should always visit the manufacturers websites, because nobody can help you better than them).
Often you can get updated drivers for your devices from them.
If the link doesn't work, you can copy and paste the following address:
http://www.asus.com/products.aspx?modelmenu=2&model=404&l1=3&l2=11&l3=144&l4=0
In the Expansion Slots( the ones you use for graphics adapters) the performance decreases from top to bbottom.
I hope that help you
