Sounds like your receiver is still swimming in water. You can try to dry it out, and with a lot of luck- well maybe.
Take the cover off (unit unplugged). Take a hair drier on med. heat and work the dryer all over. Also, use a spray can of electronics cleaner on any switches, etc, and just keep moving the hair dryer all around on the circuit board and controls. This will take as long as you have to sit there and dry it out. Probably a good idea to switch to low heat after awhile, and then go back to medium, etc.
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
