20 Most Recent Onkyo TX-8522 Receiver Questions & Answers
Make sure your mute button has not been clicked by mistake.Also make sure your in the right mode if it has a multi room option,good luck
Onkyo TX-8522... | Answered on Sep 09, 2011
Since it does not have a dedicated subwoofer pre-out, you would have to use the "TAPE" outputs. If your powered sub (I'm assuming your using a powered sub) has only one input, you could either just use the left tape out of the receiver, or use an rca splitter to convert the left and right to a single jack. (I'm not a fan of that method, though).
Onkyo TX-8522... | Answered on Jul 01, 2011
Yes it is possible. Any audio device with an earphone out jack can be connected to a receiver by using the CD input or the AUX input jacks (white and red) on the receiver. All you need is an adapter cable with the stereo 3.5mm plug on the iPhone side and the 2 RCA connectors on the receiver side. You can get these for $2 or so at Amazon.com or at Radio Shack. Adjust the volume and select on the receiver, the input you used to connect and enjoy.
http://www.amazon.com/RiteAV-3-5mm-Stereo-Male-Cable/dp/B000V0G2C4/ref=sr_1_1?ie=UTF8&qid=1306765483&sr=8-1
See above link for one example of the cable.
Onkyo TX-8522... | Answered on May 30, 2011
I've seen some posts that talk about an incorrect or too high digital audio bit rate causing this. If it's only digital sources I'd look at that.
Onkyo TX-8522... | Answered on Feb 04, 2011
Do you understand what that Monitor Button means?
Only Tape 2 can be monitored.(Page 24, diagram on page 25)
http://www.retrevo.com/support/Onkyo-TX-8522-Receivers-manual/id/469ci860/t/2/
Onkyo TX-8522... | Answered on Jan 12, 2011
Wires are falty...replace
Onkyo TX-8522... | Answered on Sep 20, 2009
T2 IS selection for EQ. ( TAPE MONITOR LOOP )Hold the T2 button down long enough and it will switch it to OFF. Karl
Onkyo TX-8522... | Answered on Sep 04, 2009
unplug unit from power.Check fuses inside unit on left side .Maybe underneath power supply board but you should be able to access them from top of unit ..replace with same type only if uses are good ..Then unit needs repair .take to your local repair shop ..
Onkyo TX-8522... | Answered on Aug 06, 2009
hi, the problem of your receiver is in the amplifier section the idle current is not working that is why the volume fades and the protection relay click to avoid further trouble of your receiver,you need repair technician to solve your problem.
Onkyo TX-8522... | Answered on Sep 11, 2008
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Onkyo TX-8522... | Answered on Jul 01, 2008
does it have speaker wire in and out use then from fronts
Onkyo TX-8522... | Answered on Feb 13, 2008
If battery replacement does not solve the problem, the next step is to to replace the remote control. However, the fault could be with the receiver.
Onkyo Audio... | Answered on Jan 11, 2021
Onkyo TX-8522 Receiver Logo
20 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
onkyo tx 8522
  • Audio Players & Recorders
