Heavy watering' Cutting roots near pot edg
Let's pretend it's an artificial plant!
The normal way to remove a plant from a pot is to hake sure the potting compost is slightly damp, then, holding the plant's stem between thumb and fingers, with the palm flat on the compost, to invert the pot. Now tap the pot gently, and the plant should slide out of the pot without damage to either. If the plant is pot-bound to the extent that roots come out of the central hole, trim these off beforehand.
When re-potting, ALWAYS pot up just one size. Spread the roots before re-potting, and make sure you use new compost.
