Question about Simplex Kaba Ilco Unican 1000 keyless lock
Do not have instruction booklet and need to know how to change the combo.
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O’CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O’CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O’CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Posted on Sep 03, 2009
I do not have the booklet on how to change to combo.
Posted on Aug 06, 2009
Feb 13, 2015 | Norpro 151 Grinder / Mincer / Pasta Maker
Feb 04, 2015 | Miscellaneous
Sep 22, 2014 | Office Equipment & Supplies
Sep 12, 2009 | Braun Ladyshave 3170 Epilator
Apr 05, 2009 | Vivitar Photography
Oct 02, 2008 | Sony PlayStation Portable (PSP) Console
Aug 08, 2008 | Deni 9100 Combo Cooker Deep Fryer
Aug 05, 2008 | Brother MFC 7420 All-In-One Laser Printer
Mar 27, 2008 | Microwave Ovens
Jan 17, 2008 | BellSouth 9915 Cordless Phone
Feb 12, 2015 | Simplex Kaba Ilco Unican 1000 keyless...
5,663 people viewed this question
