As long as it uses Windows 95 or at best XP. NO go with anything new it is a legacy Minolta machine. Minolta is Konica Minolta. See if you can get the drivers for Windows 95 or XP again at best.
Check all connections between the two main circuit board remove each connector and check for a bend pin if not replace both boards if you can find them di 250 is a legacy machine of Minolta now Konica Minolta
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware,
and communications. For remedial actions, change the board, check for cable connections,
and turn the Power Switch OFF and ON.
(6) C10]] to C13]]
C1300 1. Reset the malfunction and turn OFF and ON the Power Switch.
2. If the same malfunction persists, check the harnesses and PJs between PH
Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
