If the amp has a dedicated phono or record player jacks, then you should put them in those only. If it has not, then you can put them in any aux in sockets, however you will need a magnetic cartridge pre-amp, otherwise the record player will sound very quiet and not match the sound coming from any source.
SOURCE: turntable connection
you can not connect a turn table in any other input source other than Phono input my friend. turntable has got very weak signal thathas to be pre-amplified before getting a signal just right for a CD/Tape DVD input. you require a phono am to get an audio signal.
SOURCE: Connecting Bose 901 series iv to Harman Kardon AVR 254
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
SOURCE: I have a Pioneer PL-S50 turntable that I want to connect
hi you need a
Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
SOURCE: I need to know if there is a program that can
yes here is the link its from Microsoft http://www.microsoft.com/downloads/en/details.aspx?familyid=048DC840-14E1-467D-8DCA-19D2A8FD7485&displaylang=en hope this helps and please vote
