20 Most Recent Harman Kardon AVR 130 Receiver Questions & Answers
Your receiver manual will tell you how to switch on the optical inputs, etc. U follow the instructions and you will be all set.
Harman Kardon... | Answered on Sep 18, 2017
There is an internal reset switch mounted on the transformer board. Open the unit, look at the boards attached to the transformer, the pushbutton is facing up. Measure the voltage on the 2 pins of the switch. If it is a logic low, the switch is partially shorted. Replace the switch or just cut the jumper wire just below thw switch. When this switch fails, it constantly resets the receiver and stops it from powering up. It does not fix a protection mode problem.
Harman Kardon... | Answered on Aug 18, 2017
I dont know what to say bute it works bute i cant gett any sound from it it whas working and after i turnd it off then when i started it came no sound from it ?
Harman Kardon... | Answered on Jun 18, 2014
Why on Earth would you want to? Spend the money on some LPs or CDs.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000073294.pdf
Harman Kardon... | Answered on Apr 20, 2014
Dear every channel in the pvr must have exact ohme so if your speakers are 8ohn you must change settings on the pvr to be 8ohm it's by stander 4 ohm so you can plug 2 speakers 8 parallel way
Harman Kardon... | Answered on Nov 07, 2013
HK's must be programmed to output sound. It's probably back in the default mode and you need to go thru the menu for setup of sound output.
Harman Kardon... | Answered on Oct 15, 2013
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Harman Kardon... | Answered on May 27, 2013
Harman Kardon AVR 130 Receiver Logo
97 questions posted
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Audio Players & Recorders
Most Popular Question
harmon kardon 745 displays unlock no
  • Audio Players & Recorders
