There is no mechanical defrost timer in this particular model. You will have to run diagnostics on this. Its can be either the jazz board pt# WPW10464769 or the defrost thermostat/bimetal pt# 12001937.
I reccomend running diagnostics first.
To start with we need to start the refrigerator's diagnostic mode. To do this open the refrigerator door and press one or both door switches, depending on your refrigerator type. Next press the refrigerator temperature (+) button three times in ten seconds and release the light switch or switches. This should display an "S" in the freezer display and an "E" in the refrigerator display. Then press the refrigerator temperature (+) button one time to confirm that you want the service mode. You will then see a set of numbers displayed showing the software version for three seconds. (Again this control board is used on many different refrigerators.) After the software version is shown the freezer display should show "1" and the refrigerator display should be blank. Congratulations! Pat yourself on the back, you are now ready to do refrigerator diagnostic magic! Within the refrigerator diagnostic test mode there are 6 diagnostic tests:
1Defrost Thermostat DiagnosticsRefrigerator 2Compressor & Condenser Fan DiagnosticsFreezer 3Evaporator Fan DiagnosticsRefrigerator Sensor 4DiagnosticsFreezer Sensor DiagnosticsRefrigerator 5Damper Door Diagnostics
You can select the test number you would like to run by pressing the freezer temperature (+) or(-) button until the test number you want is in the freezer display. Then using the refrigerator(+) button to cycle the test on and off.
