There are shipping anchors that hold the drum steady when it is being moved. IF you don't take those out, when the load is no balanced the drum cannot float like it is supposed to and balance the load. IF those anchors are all out of the machine then it may be an issue with the springs or struts being loose, left out at the factory etc.
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
SOURCE: Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
SOURCE: cannot open the front door
I really did not fix the problem. I think the plastic linkage may have been broken and I was looking for a fixto open the door.
Thanks anyway,
Jim Charlesworth
