Radio Communications Logo
C
Cathy Rodriguez Posted on Jun 19, 2018
Im trying to find out how change language on a maxelf headset
2helpful
3answers
I bought LG 730 Bluetooth Headset, unfortunately the language has been changed. Let me know how can I change to English
Ion know if I'm to late.....but Ive only had the headset for 2 weeks I somehow changed the language on my headset......I did try to live with it honestly......i just started trying combinations Lmbo.......
ANYWAY I HELD DOWN THE VOLUME UP AND DOWN BUTTON AT THE SAME TIME AND THEN PRESSED THE CALL BUTTON........
SHE THEN SAID ENGLISH PROMPT AND THAT WAS IT......
How do i change the language
Daniel-
Reset settings by following directions: HX550 Reset to factory default
Mark
Motorola Support
How to change language from german to english
You need to download english version from Jabra Support web page and install it.
How to change language on hx550?
The HX550 does not have language settings you can only turn on/off the Voice Prompts, you can also check for the Voice prompts option by doing the steps below..Press and hold the Call button while turning on the
headset to turn these features on/off:
• Reset to factory default
Caution: This action erases all pairing information
stored in your headset.
• Caller ID
• Voice prompts
• Multipoint (two phone) connections
• WBS (Wide-band Audio) on/off
Follow the voice prompts to make changes to these
settings.
Note: Some features are phone/network dependent.
Mark
Motorola Support
https://forums.motorola.com/pages/home
20helpful
How do I change language with motorola hk250 headset from italian to english
Turn off the headset. Then hold down the call button and turn the headset on again. The voice interface will ask if you want to continue in a number of different languages. When they ask if you want to continue in the language you want, press the call button again to select that language.
1helpful
Im trying to pair my iphone with my blueant but it keeps saying (make sure blueant st3 is turned on in range and ready to pair)
First off the device you are referring to is a ST3 and not a Z9. What you need to do is put the device into pair mode prior to searching in your iphones bluetooth menu, to do this with the device off hold down the green button until you hear a language loop. When you hear the language of your choice let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go to your Iphones bluetooth menu and select the ST3 and it should work.
Regards,
Rylan
Quick cam im
the problem on that case is the microphone in your headset. i can't see any problem on the installation or software. try to change another headset or microphone. make it sure you inserted well the jack of headset at your PC.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
