SOURCE: Remote Control Codes don't work with my LCD TV
There is no code!!! -- Solution...You have to buy a universal remote with learning capabilities. I’ve ordered one that will not only learn off other remotes but can handle 10 components also. I got it from 10x it’s called the iconRemote control…if you call the company they will give you a discount (but you have to call them and ask) AWESOME!
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
SOURCE: remote code for att uverse to sylvania lc320slx lcd tv
My solution might be a little off because I called Comcast for the answer but it seems that the problem is that the code doesn't exist.
I called Comcast and they had no clue. But I called Sylvania and their
reps were FABULOUS!!! Turns out, the TV makers send the cable companies
the frequencies for each TV then the cable companies send them to a 3rd
party to get the codes written.
This model of TV is new and there is no code written. The rep suggested
that we countinue to check back on the Comcast website regularly to see
if the code is posted. She said that the sales reps tend to get the
info last.
The Sylvania rep anticipates a new code written soon because this is such a prevelant problem.
SOURCE: I need a remote code for my Sylvania TV. LC320SLX
info last.
The Sylvania rep anticipates a new code written soon because this is such a prevalent problem.
SOURCE: direct tv remote code for Sylvania LC320SLX
Get the Direct TV RC65 and program in code 11864. It works I just programmed my LC320SLX.
