20 Most Recent Sylvania 6509DD 9 in. TV/DVD Combo Questions & Answers
Some universal remotes do not correctly handle the features of the original remote. You can get an exact duplicate remote from remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=6509DD&uuid=12709186471510
Alternatively, get one of the higher end programmable remotes. The ones programmed from your computer are more likely to be trainable to do all the features of your original remot.
I hope this helps.
Sylvania 6509DD... | Answered on Apr 10, 2010
Try a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sylvania... | Answered on Oct 13, 2020
It's the fuse in the electric engine. You can bypass this fuse by cutting it off and then you just connect the two ends together, wrap with electrical tape. It'll work, that's what I did to mine. Works great again
Sylvania... | Answered on Sep 06, 2020
A lot of people are confused about turning the TV 'off'. If there is a light showing when the TV is 'off' it is merely on 'stand-by' and not truly off. Off means being physically turned off by either the switch on the set or the mains. using the remote to turn 'off' the TV will not turn off it will only put the set into stand-by mode. In many cases if the TV is in stand-by mode, and then switched off, when the set is turned back on, it will still be in stand-by mode, and will need to be turned on with the remote. (even if you unplug, in some cases) All TV's are different, so will operate differently of course.
Sylvania... | Answered on Jul 17, 2020
Did you finalize the DVD before you removed it from the VCR/DVD recorder? Until a disc is finalized, it won't work on another device. If you left some space, try to finalize it now. Does the disc play when in that Sylvania unit? It is possible that the unit is faulty and didn't focus the laser properly for writing to the DVD. (If you actually tried to burn to a CD and not a DVD-R, then no data was written to the disc. There are slight differences to the laser settings for CDs and DVDs.)
I hope this helps.
Sylvania... | Answered on Jun 24, 2020
Try contacting Curtis International Customer service at 800-968-9853 and request a user manual if French.
Sylvania... | Answered on May 18, 2020
Consider using 'auto search' on Motorola.
how ?
Turn on your TV and point the remote at TV during setup
1. Press and hold SETUP until the LED blinks twice
2. Press the TV POWER key.
3. Aim the remote at your TV and press and hold down the OK key.
4. Release the key when the TV turns off and setup is complete.
Sylvania... | Answered on Jan 07, 2020
consider using 'auto search' on Motorola.
how ?
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Sylvania... | Answered on Dec 16, 2019
Curtis International which made the Sylvania clock radio no longer has any support for its legacy electronics. ManualsLib has manuals for several Sylvania clock radio models here: https://www.manualslib.com/brand/sylvania/clock-radio.html . They have a link for the SCR1388B, https://www.manualslib.com/manual/944856/Sylvania.html . This document doesn't list the SCR1388B on the cover page. However, the two clock radios are probably similar enough that the manual will help you use your clock radio. If this manual doesn't provide enough details, please check some of the other manuals listed at the first link above.
I hope this helps. ManualsLib does provide an option to get the manual as a PDF. See the Download button near the top of the page. You will need to go through some CAPTCHA checks to download the file as a PDF.
Sylvania... | Answered on Dec 13, 2019
Copy any video file like AVI, MP4, MKV,WMV to USB drive, plug the USB drive and select USB and play it, should play movies
Sylvania... | Answered on Nov 30, 2019
Hi Elsie-
If you do not have the remote, you can change inputs by doing the following:
Changing inputs Inputs are selected by using a number of methods, depending on the model of your Sylvania TV. Switching inputs is usually accomplished by pressing the "Input Select" button on the remote. Each press will simply cycle through each available input on your TV. If no remote is available, the front panel has a button that matches the function on the remote. This button is located on the bottom-right side of the TV and doubles as the "Enter" button when accessing onscreen menus.
Hope this helps.
Sylvania... | Answered on Nov 27, 2019
Sylvania 6509DD 9 in. TV/DVD Combo Logo
Popular Tags
7 questions posted
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
dvd portion sylvania 6509dd 9 inch able
  • Televison & Video
