SOURCE: garmin etrex handheld
There's really nothing to setup, you just mark waypoints and it displays them on the map. If you press enter on any screen, it will give you options for that screen.
SOURCE: Garmin GPSmap 60CSx and geocaches
Search for them "by name" instead of "by nearest"
Find>waypoints>find>menu>enter>by name
Only the nearest 50 caches show up and then only if they are within 50 miles.
SOURCE: Geocaching with Garmin Etrex Legend CX
The preloaded maps are VERY generic, mostly major highways. They are not useful for geocaching.
The good news is that you can download free topo maps created by a very generous Canadian soul, Dale Atkin. The maps are free but donations are accepted. He is also working on US topo maps. I've used Ibycus and Garmin topo maps and prefer the Ibycus version.
If this solves your situation, please come back and rate our answer. Thankyou.
SOURCE: I geocache with a friend.
Depends on the number of satellites each GPS is viewing at the time so if you are holding the device your body will be shielding a number of satellites from the device and this may be different depending which direction you are looking in. The other thing is that 10m/40ft is about the best accuracy you can get from a standard GPS. If you want better accuracy you need a surveying GPS with a Differential GPS receiver
Peter
Yes, have you enabled WAAS on your 60CSx? WAAS is an acronym for Wide Area Augmentation System, according to the instruction manual an FAA funded service to improve overall integrity of the GPS signal through North America.
If you are in an area which is not serviced by ground stations, having WAAS enabled may degrade the signal from the GPS satellites. Try enabling or disabling this feature.
To do so, acess the System Startup Page. On the Setup Menu page, highlight the System icon and press Enter. WAAS is the second available setting on this page.
Make sure your batteries are fresh; I prefer alkalines in this model. Set the battery type in the System Setup Page, same page as noted for WAAS above.
Another thought is to be sure you have the latest Garmin software installed. Visit their site to download the latest and greatest, free, of course.
On 10 October 2010 geocachers around the world held events
and went caching to commemorate 10 years of geocaching. In the process
they set a record for the most geocachers to find a cache in a day, with 78,313
accounts logging a cache
