Http://kingoffans.com/#/ContactUs/form
I used online chat instead of email:
___________________________________________________
CS Rep 3:
Hello! How are you doing today, thank you for visiting our website for support assistance. It will be my pleasure to assist you today.
Please tell me what you would like my help with today?
Terry:
Looking to see if you sell the Hampton Bay blue neon light kit part number 46276N.
CS Rep 3:
May I have the upc number for the fan ?
Terry:
I believe it is 082392372255 but I am not certain - that UPC is from an internet search.
CS Rep 3:
We have the light kit available the price is $60 + $ 17 for shipping
Terry:
Can I refer someone to you to purchase it?
CS Rep 3:
Yes sure my direct phone number is 800 749 3267 ext 4091 my name is Alitza
Terry:
Thank you.
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
SOURCE: need replacement blades
Although we do deal with Hampton Bay fans ourselves, here's a link to someone who does:Contact Mike Evans
Website: www.eceilingfans.com
Phone: 979-553-3260
Ceiling Fan Parts & Service
SOURCE: change light
i just put fluorescent lights in two of these fans. it just takes a little fabbing and its done and simple.
Go to home depot and buy a lithonia lighting 11" low profile round light model# FM22 ACLR LP.
tools:
drill
rotozip or file
wire strippers
crescent wrench
screwdriver(phillips)
you can take the neons and the power supply off of the fan base but be sure to save all the screws, you will need them later. the ballast in the light will fit in the chrome base on the fan but you have to shave one of the bolt holes down first for it to fit (be sure not to cut the ones that the bolts go through). you do not need the green ground wire from the new light.
Next drill out the rivets from the bulb brackets on the new light base. now you can take the bulb and place it on the fan backing plate and get your bulb brackets and mark where you will mount them. then drill holes for them (but make sure the holes are for the screws that you saved earlier because you will reuse them for the light brackets). Be sure to mount the bulb as center as possible.
now once you have fabbed everything put the assembly up to the fan and pull the wires down through the ballast and through the center tassle bolt and wire it up. the bulb is an 8" bulb and thats all that will fit. home depot sells phillips 8" bulbs in several different brightnesess.
this picture was taken on my phone so it isn't that great. but the light really brightens it up.
SOURCE: Trying to connect a ceiling fan light kit.
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
I search eBay and Home Depot and did not see this listed. Apparently about 5 years old.
Might send email to kingoffans in Florida:
http://kingoffans.com/#/ContactUs/form
