We need to get better air flow on these 2 ceiling fans. Are there any adjustments that can be made on fan to get better air flow, or do we need to use a longer extension rod. We checked the direction on the both fans they are going clockwise. Do you think getting longer extension rods may improve the air flow?
Ceiling fans have a direction switch in the cover just above the fan motor
it is very possible that during the installation this switch was moved to the wrong direction for the fans to blow down
get a good step ladder and with the fan off check the fan switch and move it to a new position
there should be a small tag saying rev/fwd or up/down
when looking up at the fan , it should be rotating clockwise
Testimonial: "The fans are rotating clockwise, but the air flow is not so good. We have the same fan in our bedroom but our ceilings are only 8ft. & it works fine. Do you think if we get a longer extension for the family room will it work better?"
The fans are going clockwise. We have same fan in our bedroom our ceilings are 8ft. and the air flow is great. Do you think if we get a longer extension rod in the family room, do you think the air flow will improve?
