Good morning Christine, F10 error code is runaway temp. You probably have a bad temp sensor that isn't sending the correct temperature to the control board. Should be able to remove from inside toe oven but you may need to access the back of the oven to get to the screws. Not the hardest job in the world but kind of a pain. Hope that helps.
SOURCE: Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
SOURCE: What does F10 display on my stove mean? Frigidaire Model PGF355DS
my frigidaire oven keeps flashing f10 and turning off
SOURCE: F10
Hello,the F10 error code means "Runaway temperature"most likely the
problem is bad Electronic oven Control ("clock/timer").it has to be
replaced together with the overlay because it's glued to the clock.
Thanks
