Ovens Logo
Question about Ovens
What does F10 display on my stove mean? Frigidaire Model PGF355DS
Stove FrigidaireF10 display
Posted by dorothyh1949 on
Anonymous
My frigidaire oven keeps flashing f10 and turning off
Posted on Aug 21, 2009
Kenmore gas oven built in. It has F10 Error Code on the control panel display.
Question edited for clarity.
You need a service call. It's dangerous.
The F10 code on a Kenmore oven means that the oven is overheating - the oven is detecting a temperature far over the safe range of operation. Most models also start beeping when this happens since it can be a safety concern.Apr. 14, 2020
How to Troubleshoot Error F10 on a Kenmore Stove ' Hunker
https://www.hunker.com > ... > Other Home Appliances
About featured snippets
Crosley oven dont work f 10 gas
The "F10" oven error code means "Runaway temperature"
try this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/70424-what-does-f10-error-code-mean.html#ixzz2VTV50IJ4
Jun 06, 2013 • Ovens
2helpful
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
1helpful
F10
Hello,the F10 error code means "Runaway temperature"most likely the problem is bad Electronic oven Control ("clock/timer").it has to be replaced together with the overlay because it's glued to the clock.
Thanks
1helpful
My oven is sending a code on the digital display F10 it does turn on and heat up but then after a few minutes i get the F10 code the top of the stove(burners) are operating fine
this is usually the code for a runaway temperature. it means the control thinks the oven is too hot.
you might have a sensor that is out of range and it can be replaced easily.
try this and it should fix your troubles
Jan 09, 2010 • Ovens
2helpful
What does it mean when the oven beep and F10 is on the screen
Go online and type in your model number and ask what the F10 code means. Every stove is slightly different. Mine did the same thing and the F2 code came on. Meant the sensor was gone and I replaced it in 10 minutes for under $80. Even a novice can do it. Perhaps same with yours, perhaps not.
1helpful
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
Top Ovens Experts
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
