Televison & Video Logo
M
Merlin Posted on Jan 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
White vertical bars on HP PL4260N Plasma TV. What recommendations for repairs and or boards affected in TV set
L Vincent Testa
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • HP Master 724 Answers
  • Posted on Jan 26, 2018
L Vincent Testa
HP Master
Level 3:
Renaissance:
Answers
724
Questions
0
Helped
367467
Points
3088
If those bars are vertical are going up and down and not horizontal that means the lower circuit board that connect to the plasma panel are bad most likely this is an LG TV but this is not something that can be fixed you can take it apart while at least an hour after it's unplugged before you can touch ID cards along the long circuit board see if there's any connection connection connection that you can disconnect and reconnect and very carefully clean up possibly this could be the problem but usually when you have that type of line which is a vertical line you have a bad panel and that's not good and I'm betting this is an LG TV
Testimonial: "Thanks for the response. It is an HP PL4260N Plasma TV. Purchased back 2007. Trying to decide if worth purchasing repair boards or simply scrap unit."
5 Related Answers
salt56
TV Doctor Repair Consult
  • 373 Answers
  • Posted on Dec 31, 2007
SOURCE: Glare - HP Plasma TV Model PL4260N
Requires taking the back off: There is a module about 1 and a half inches square with 4 controls on it (looks like a small phillips screwdriver will fit.) Sits vertically. A yellow one on the lower left side. Tweek or turn it just a little about 2% and watch the picture and seen if the problem goes away. First unplug the tv before taking the back off and when back is off position the tv and yourself to turn the control and turn the tv on. You will need someone to turn tv on for you. Then do the tweeking with someone watching the picture for you
Anonymous
  • 36 Answers
  • Posted on Jan 17, 2009
SOURCE: No picture, audio OK, HP PL4260N, outside HP's repair for common Problem
I had the same problem and HP has been very helpful, try calling this number 877-917-4380 ext. 79 and be firm tell them this needs to be fixed. They are sending my second replacement part and said they will keep sending parts till it works, this tv is almost 3 years old.
Anonymous
  • 326 Answers
  • Posted on Feb 19, 2009
as its necessary to replace the y board if its faulty. try  www.partstore.com for cheaper price boards.
Anonymous
  • 8 Answers
  • Posted on Mar 20, 2009
SOURCE: Black screen on HP PL4260N 42? Plasma HDTV
The problem is the "Y-SUS" board. It is inside the set on the left side with several aluminum heat sinks, under the left side brace bar. You can order this board from Union Electronics at www.ued.com .Search for part number: TNPA3243AB-PA
It lists for about 115$
Robeye
  • 81 Answers
  • Posted on Jun 30, 2010
SOURCE: where can i obtain a lamp for the hp plasma tv
Sorry, your plasma does not take a lamp.
"Plasma flat screen technology consists of hundreds of thousands of individual pixel cells, which allow electric pulses (stemming from electrodes) to excite rare natural gases-usually xenon and neon-causing them to glow and produce light. This light illuminates the proper balance of red, green, or blue phosphors contained in each cell to display the proper color sequence from the light. Each pixel cell is essentially an individual microscopic florescent light bulb, receiving instruction from software contained on the rear electrostatic silicon board. Look very closely at a plasma TV and you can actually see the individual pixel cell coloration of red, green, and blue bars. You can also see the black ribs which separate each."
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
My HP PL4260N 42 In. HDTV Plasma Television tv doesnt show anything but i can still hear
If your TV is plasma the only part you need to replace or check is y sustain board..You should replace it to work fine again
1helpful
3answers
I am getting a black screen and the sound works the color has been going in and out white but color still worked but it just went black so i contacted hp help and they say it should be a board part is...
You most certainly do not want to disassemble the tv. HP has made a valid diagnosis, you would be best off taking the replacement board and tv to a repair shop and have them change it for you. Yeah, it may cost a little, but Plasma TVs have very fragile displays- very easily broken.
8helpful
2answers
I have no picture but have power to my hp tv
Hi Deko11
Just repaired my Hp PL4260N.
The Y SUS board can be defective and they cost about 70. plus shipping or a repair kit on Ebay and if you are are replacing the board yourself, it is the board on your left whenthe tv facing down and you are at the bottom of the screeen
Where can i obtain a lamp for the hp plasma tv model#pl4260n
White lines at the top of my hp 42 inch plasma tv.
This HP model is know for many defects. It was sold by HP with a board problem. Contact us to get your TV fixed as a group. [email protected]
Vertical bands on right half of screen, left half perfect.
its usually replaced along with the ZSUS board
replace that and it should solve the problem
its not hard to locate that both
with the back cover open its to the right side of the kinda
kinda looks like the YSUS board
not hard to find at all
HP PL4260N source list entries are all "Cable"
Video board is most likely damaged from a electrical spike, you may try looking at the capacitors on the boards inside the tv and see if they are damaged capacitors are an easy solution to problems some of the time.
Tv screen is black and flashes white
HP sold this TV with a bad board and they knew it was bad but still sold the TV's anyway. Our group is taking action to protect consumer from this type of corpoarte greed. Contact us: [email protected]
1helpful
2answers
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
