Will I be able to connect the Janome to the pC either via USB cable or RS-232? If so what cable(s) should I purchase.
For instructions on connectivity, go here:
http://janome.com/en/learn/software-lessons/transferring-designs/communicating-with-the-memory-craft-10000/
For the User Guide, go here:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj4qf7qoYzYAhUq6YMKHT_jARsQFgg6MAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fretired%2Fembroidery%2Finst-book-mc10000-book-1.pdf&usg=AOvVaw3HWaMfuQE6ewNtFjlHTD39
You need to use an RS-232 or USB cable for that machine. But your PC obviously has to have that kind of port on it. And Windows Vista will likely be very testy about recognizing that thing. Hopefully, you don't intend for the PC to be online while using the embroidery software. If so, you need to stop using Vista (or lower for that matter) as Microsoft has not supported it since 2014. OK to use Vista for a while after 2014 because Windows Update still gave security updates for other Windows products (Word, Works, etc.). But now, Windows Update for Vista will not work anymore for anything. At least switch to Windows 7 as Microsoft will probably support it until 2020. However, I understand the dilema - maybe the software won't work in Windows 7, maybe it will. Hopefully you have the software for it (CD-ROM discs). Anyway, if you intend to use the embroidery software with Windows Vista or XP while not online, it should be OK.
SOURCE: Cannot get Janome 10001 to read via USB direct link from computer
I was having the exact same problem and just a minute ago was able to fix this. If you have the original installation cd for customizer 10000 plus when you first connect your usb cable from the machine to your xp machine choose the option to install the new hardware yourself. Then point to the cd rom drive and the drivers folder, win 2000 and the file inside of that will be the driver file. As soon as you install from this file it will be successful and you will be able to see all your Janome 10001 machine files on your computer when you work with customizer 10000 plus software. Let me know how it goes.
ec
SOURCE: DOWNLOAD PHOTOS FROM LG PHONE TO PC VIA USB CABLE
You have to have an SD card and also a port for your computer to read SD Cards. You could send them through pic message but that takes awhile. Good luck.
SOURCE: Need Windows XP USB driver for Memory Craft 10001
contact me back at [email protected] and i will send you all the drivers i have.
when i got mine working, i believe sometimes it is just by LUCK that things work.
SOURCE: JANOME MEMORY CRAFT 5700 INSTRUCTION BOOK
Hi, I downloaded (for free) a copy of the Envision 8006 (and 8007 supplement) manual from the Elna website 2 1/2 years ago. The Envision 8007 is the same as the Janome Memory Craft 5700. I can email you a copy of the manual.
SOURCE: Baby Lock Embroidery Sewing Machine
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
