20 Most Recent VIA Epia M10000 Motherboard Questions & Answers
tip
Reflash Via EPIA-M 1000g BIOS when board is dead
I'm writing this in the hope that others like me can resolv their problem with the dead EPIA-M mainboard.The symptoms where.. on power-up .. it would make 2 high pich beeps followed by 2 low pich beeps..turned out that is the error code for dead BIOS.OK so u have a dead bios and a mobo that won't boot for various reasons.. from flashing a wrong or corrupted bios or else.Apart from the other ways to go around the problem like buying a new chip already flashed or flash the chip with a dedicated flasher u can follow on this simple guide.You should at least have some experience in DIY in computers .1. Find a mobo of an old  pc that uses the same socket for the bios chip.if it uses award bios even better.I used a biostar p4m800-m7a mobo to do this.No need for it to have a hdd or something special attached to it.. power source and cd or dvd/rom will do.2. Try to see if it boots, if all ok..3. Get you hands on the Hiren's boot cd..burn it and boot from cd..it has in the Dos program list... in the next page BIOS/CMOS UTILITIES. Select uniflash 1.4.. i did it with the 1.4 on the hiren's boot cd 10.1 maybe if they update it it will work also.It will tell you the name of the bios chip and some details..make a backup of original chip just in case.4.On other pc download the 109.BIN file .. the bios file known to be stable for the EPIA-M board. You can find it on some forum.. i can't remember now..I thank them by the way.Same the file on a fat32 usb key.5.On the surogate board with uniflash started.. comes the tricky part: u have to get hold of some good tools and pull the bios chip out while it's running... don't worry, nothing will happen.6. Pull out the dead bios chip of EPIA-M and put it in the surogate board.These steps must be done with absolute care.If you think you can't do it, wait or call a friend with more experience or get hold of the right tools7. Now with the dead bios chip in place.. select in uniflash, rediscover bios chip.. or something like that,..can't remember well.. but you get it when you see the screen... the sst bios of the EPIA-M NOW SHOWS UP...8. select flash bios and select the file on the root of the usb key by typing C:\109.bin.. if no hdd attached.. the key is seen as C, otherwise use letter accordingly.It flashes the bios in less that 10 seconds.. and says ok.. power off surogate mobo.. replace bios chip with original.. and enjoy now your EPIA-M mainboard again.If you'd like to thank me or ask details..mail me at [email protected]
Epia m10000 pc case internal speaker
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you if you dont have a motherboard disc you will have to download the drivers
8/25/2011 9:52:00 PM • VIA Epia M10000... • Answered on Aug 25, 2011
I pulled the jumpers off the audio pins on the
Go to this page on the via website, towards the bottom you'll find a link UM_EPIA-M_150.pdf
which is the manual for the epia motherboards
4/12/2010 2:02:54 AM • VIA Epia M10000... • Answered on Apr 12, 2010
Troubleshooting brinksmann vacuum
Refer to link @ manualslib.com for trouble shooting guide or provide year, model number, serial number, symptoms. 1443ac81-1efb-4e5d-993a-af4a3fd1a4e1-xbfj0r3nqbrmhqpr5bt2alsr-d-0.jpeg 1443ac81-1efb-4e5d-993a-af4a3fd1a4e1-xbfj0r3nqbrmhqpr5bt2alsr-d-1.jpeg 1443ac81-1efb-4e5d-993a-af4a3fd1a4e1-xbfj0r3nqbrmhqpr5bt2alsr-d-2.jpeg
3/20/2023 1:05:03 AM • VIA Computers &... • Answered on Mar 20, 2023
2answers
Bose 321 series 2 to computer
The best way is always via USB. That is how I connect my Bowers and Wilkins MM1 speakers, but you need the Drivers. Bose has a section on setting up on their website. https://www.bose.ca/en_ca/support/guides/articles/productCode/321gs_series2/guides.html?category=Connecting%20other%20products ..
1/2/2023 9:39:18 AM • VIA Computers &... • Answered on Jan 02, 2023
Hard drive not showing error code 43 port reset failed can anyone help?
Hi, Please use Geeksquad to help transfer your data from that hard drive before throwing it away. If it's malfunctioning now, you're not going to want to store anymore data on it. Thank you.
10/5/2022 6:48:19 PM • VIA Computers &... • Answered on Oct 05, 2022
tip
How cloud computing is changing the world?
Cloud computing is the delivery of computing services via the internet rather than through local servers or personal devices. Servers, storage, databases, networking, software, analytics, and intelligence are all examples of computing services. These services are transferred outside of an organization's firewall and are available over the internet. Cloud computing reduces operating expenses and enables efficient scaling because consumers pay on an as-needed or pay-per-use basis. As Cloud Computing is a buzzword in the IT industry, If you want to pursue a career in Cloud Computing then you can go for a Cloud Computing Course. CHARACTERISTICS OF CLOUD COMPUTING According to the National Institute of Standards and Technology (NIST), all true cloud environments have five key characteristics:
  • On-demand self-service: Cloud customers can easily sign up for, pay for, and begin using cloud resources without the assistance of a sales professional.
  • Customers can access cloud services through a wide network, such as the internet.
  • Resource pooling occurs when multiple types of consumers (individuals, organisations, or departments within an organisation) use the same servers, storage, or other computing resources.
  • Rapid flexibility or expansion: Cloud users can simply scale up or down their utilisation of resources as their needs change.
  • Measured service: Instead of purchasing hardware or software up ahead, customers pay for the amount of resources they use in a certain period of time. (It should be noted that in a private cloud, this metered service usually entails some type of chargebacks in which IT keeps track of how much resources different departments within an organisation use.)
on May 05, 2022 • Computers & Internet
tip
Example: How to change your mp3 player background
Cloud computing is the delivery of computing services via the internet rather than through local servers or personal devices. Servers, storage, databases, networking, software, analytics, and intelligence are all examples of computing services. These services are transferred outside of an organization's firewall and are available over the internet. Cloud computing reduces operating expenses and enables efficient scaling because consumers pay on an as-needed or pay-per-use basis. CHARACTERISTICS OF CLOUD COMPUTING According to the National Institute of Standards and Technology (NIST), all true cloud environments have five key characteristics:
  • Resource pooling occurs when multiple types of consumers (individuals, organizations, or departments within an organization) use the same servers, storage, or other computing resources.
  • Rapid flexibility or expansion: Cloud users can simply scale up or down their utilization of resources as their needs change.
  • Measured service: Instead of purchasing hardware or software up ahead, customers pay for the number of resources they use in a certain period of time. (It should be noted that in a private cloud, this metered service usually entails some type of chargebacks in which IT keeps track of how many resources different departments within an organization use.)
Why does Glarysoft's Malware Hunter Pro show protection as OFF?
Contact Support. 'Protection Off', means that it is turned off and not protecting you. Do you also have Windows Defender active on the machine? Windows may have turned the competitor off, or your subscription has expired.
Malware Hunter PRO - Glary Utilities
https://www.glarysoft.com > malware-hunter Virus Scan. Scan your computer quickly and thoroughly. · SpeedUp. The Speedup section on Glarysoft Malware Hunter Pro helps you optimize your system performance.
4/26/2022 4:44:30 AM • VIA Computers &... • Answered on Apr 26, 2022
Where can I get this bios firmware file AN10YV192
If it as a dual bios chip, restore from the older bios to overcome issues. The only place the bios updates are available is from the manufacturers web site, if available.
4/25/2022 3:45:08 PM • VIA Computers &... • Answered on Apr 25, 2022
Why does Windscribe VPN keep showing an error when I connect via IKEV2 protocol on Windows PC?
Your VPN might not be compatible or work with the program and the software that your computer uses.
8/23/2021 8:13:11 AM • VIA Computers &... • Answered on Aug 23, 2021
Webroot Antivirus Customer Service Phone bhenchod fails again
ask them yet, call them and ask, we cant call for you. here is there contact page, do that yet. https://www.webroot.com/us/en/support/support-home
12/3/2019 2:06:18 PM • VIA Computers &... • Answered on Dec 03, 2019
My son needs an affidavit that he is unemployed from the department of labour where do we go or can it we obtained via the internet?
Unable to tell you without more information. Use the comment menu in FIXYA if you can provide details. For example, what city or country could he be in, perhaps you can answer. We usually recommend using https://www.google.com to search for answers to questions like yours, although we prefer repair questions for do it yourself issues about equipment. Regards.
8/28/2019 12:36:31 PM • VIA Computers &... • Answered on Aug 28, 2019
Mini display port and TCLRoku tv to macbook air, fonts are blurry/not HDMI/crisp at all. This includes fonts in terminal && Coding editors as well , can you help?
Sounds like the resolution of your Macbook Air video adapter it much higher than what is supported by the Roku or TV.
8/26/2019 8:49:40 AM • VIA Computers &... • Answered on Aug 26, 2019
My Via 280 will not boot up after being on charger for several hours
Sounds like the battery in the device needs to be replaced.
8/26/2019 8:45:08 AM • VIA Computers &... • Answered on Aug 26, 2019
Trying to get onto netflix via my tv but can no longer get on as it says Please check your network connection
Sounds like your TV is no longer connected to the internet. Check WiFi or Ethernet cable connections and try again.
8/26/2019 8:43:55 AM • VIA Computers &... • Answered on Aug 26, 2019
VIA Epia M10000 Motherboard Logo
6 questions posted
Top VIA Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
shadow
MegaByteMe
MegaByteMe
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • VIA Computers & Internet
Most Popular Question
epia m10000 pc case internal speaker
