SOURCE: Bijoux Terner
If you are having trouble setting the watch there could be an issue with the movement itself! I suggest taking to a watch repair business and having them take a look. If the movement is bad it shouldnt cost too terribly much to replace it.
Posted on Jan 09, 2010
SOURCE: I need a user manual for a Pasnew watch Model
First off, press the "mode" button for 3 seconds.
Secondly, after the watch enters the "Time Editting Mode", press the "mode" button for 1 second (Clearly to say, it's recommended that you should release immediately right after you press it).
Lastly, press the "start" button to navigate through hour, minute and second numbers. In order to change those values, you need to press "alarm" button several times. Hence, the values to be set increase.
Posted on Oct 26, 2010
SOURCE: I have a WR30M Watch
Follow these steps to adjust the time :
Step 1. Press and hold MODE for 2 seconds and then release. The watch will be in alarm mode.
Step 2. Press mode again to enter time mode adjust.
Step 3. Press the stop button to cycle through what you want to adjust.
Step 4. Press the reset button to adjust the actual item.
Step 5. Press MODE to exit time setting mode.
Hope this helps
Posted on Nov 24, 2010
SOURCE: How do I adjust the time automatically for
go here for manual > http://www.timex.ca/en/manuals.aspx
Posted on Nov 22, 2012
SOURCE: How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Posted on Dec 15, 2015
