Follow these steps to adjust the time :
Step 1. Press and hold MODE for 2 seconds and then release. The watch will be in alarm mode.
Step 2. Press mode again to enter time mode adjust.
Step 3. Press the stop button to cycle through what you want to adjust.
Step 4. Press the reset button to adjust the actual item.
Step 5. Press MODE to exit time setting mode.
Hope this helps
Posted on Nov 24, 2010
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press mode to stop
Good Luck
SOURCE: Bijoux Terner
If you are having trouble setting the watch there could be an issue with the movement itself! I suggest taking to a watch repair business and having them take a look. If the movement is bad it shouldnt cost too terribly much to replace it.
Posted on Jan 09, 2010
SOURCE: how do I set the time on My watch WR30M
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Posted on Jul 23, 2010
SOURCE: Setting Time and Date on a Timex WR30M
I solved going to Quemex.com / Service / LCD watch instructions.
No more beep.
Posted on May 13, 2008
Mar 21, 2018 | The Watches
Dec 13, 2017 | Timex Watches
Nov 09, 2017 | Watches
Sep 10, 2016 | The Watches
Dec 15, 2015 | Watches
Apr 13, 2012 | Watches
Mar 06, 2011 | Timex 27191 Wristwatch
Oct 29, 2010 | Watches
Feb 17, 2021 | The Watches
25,121 people viewed this question
Again, I have a WR30M watch with 4 buttons to push, Light, Mode, Start, Reset. How do I set the time and date on the watch.
It gose back to 2:57
HET LUKT NIET
