SOURCE: Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
SOURCE: Microwave oven glass window on the door
do not use - there is a possibility of microwave leakage.
SOURCE: Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Rust inside the microwave oven
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting
membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and please do not leave it running
unattended.
On this model, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame which comes with a new keypad.
In this case, you simply
move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find
helpful exploded view diagrams and order parts by entering your full
model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
We're
happy to help you with free advice and we'd appreciate your
