20 Most Recent Sunbeam SBM1000 Microwave Oven Questions & Answers
Microwave won't heat
replace Magnetron..
8/19/2014 6:04:28 AM • Sunbeam SBM1000... • Answered on Aug 19, 2014
2answers
Tuntable keeps rotating when microwave door is open
get a new microwave its nackered
8/19/2014 5:58:56 AM • Sunbeam SBM1000... • Answered on Aug 19, 2014
The power button beeps twice, but will not reduce
Hello, Thank You for using FixYa. I will be helping you today.Are you selecting the power level before selecting the time?
Thank You and please rate my answer if it was helpful..
6/15/2011 3:19:18 PM • Sunbeam SBM1000... • Answered on Jun 15, 2011
My brand new Sunbeam microwave
Can not find a fuse for a Sunbeam microwave model SGG5701. Where can I find one? My microwave went out after only 3 months of having it.
5/17/2011 12:54:19 AM • Sunbeam SBM1000... • Answered on May 17, 2011
Microwave wont turn on
Remove the cover and find the fuse on the floor of the oven near where the cord enters. Check with a continuity checker or Ohm meter. Find replacement at your hardware store.
2/14/2011 3:06:42 AM • Sunbeam SBM1000... • Answered on Feb 14, 2011
The microwave runs but does not heat?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
1/6/2011 4:17:05 AM • Sunbeam SBM1000... • Answered on Jan 06, 2011
Turn table doesnot turn
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARRAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
1/5/2011 9:19:43 PM • Sunbeam SBM1000... • Answered on Jan 05, 2011
2answers
Does not cook food
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
6/15/2010 12:02:41 PM • Sunbeam SBM1000... • Answered on Jun 15, 2010
THE BREAKER IN MY KITCHEN WENT OFF AND WENT IT WAS
hey there welcome to fixya
it is most probably a fuse that you would have to replace the best thing to to is to take it to a local electrician to get it replaced
thanks for using fixya
regards magicalink
6/9/2010 6:28:04 PM • Sunbeam SBM1000... • Answered on Jun 09, 2010
Need to buy new turntable for s.s. Sunbeam
For assistance with your Sunbeam Microwave, you can call 1-866-257-3336.
12/8/2009 10:01:14 PM • Sunbeam SBM1000... • Answered on Dec 08, 2009
The turn glass plate inside don't fit right, it
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well your symptoms "glass plate won't fit".
11/29/2009 7:40:37 PM • Sunbeam SBM1000... • Answered on Nov 29, 2009
Broken glass plate number on it 22873 01
You can get one from repairclinic.com
9/23/2009 7:56:39 PM • Sunbeam SBM1000... • Answered on Sep 23, 2009
Sunbeam SBM1000 Microwave Oven Logo
34 questions posted
Top Sunbeam Microwave Ovens Experts
Paul Bade
john h
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Microwave Ovens
Most Popular Question
microwave wont turn
  • Microwave Ovens
