SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
SOURCE: Output pressure same as input pressure.
check the presure regulation valve after you are sure that isnt damaged from ice.
Sulejman Sulejmani
SOURCE: pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: Cant get any pressure build up... acts like a hose to water flowe
looks like you will have to get the diaphragm seals in the pump replaced
SOURCE: gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
