20 Most Recent
Mi T M WP-3000-4MHB Pressure Washer Questions & Answers
My 3000 psi has no
The pressure valve is possibly stuck open. First of all try spraying some WD40 up the water inlet valve and leaving it for 30 mins or so. Then reconnect the hose and try again.
It is entirely possible that the seal on this valve is ukid or in other words breached. I had my own fail about 6 months ago and had it replaced as well as a full service for $150.00.
Please rate my help++++Thyanks for using FIXYA
5/13/2010 3:29:32 AM •
Mi T M...
Answered
on May 13, 2010
I pulled the power stater pull string but my
you can check for spark by unscrewing the spark plug , place the rubber boot back on the plug and have someone gently pull the starter rope while you hold the electrode of the plug so that it touches the engine block. make sure not to touch any part of the plug or you will get a shock! only hold the plug by the rubber boot! while a helper pulls the rope you should see a spark in the electrode of the plug if you have it grounded against the engine case. if you have spark then try spraying a little starter fluid in the spark plug hole or the air cleaner. either will work and should get it to fire if it has spark. if it starts and then shuts off, your carb is probably gunked up.
4/28/2010 5:44:52 PM •
Mi T M...
Answered
on Apr 28, 2010
How much psi does a 3000psi power wash have when
James,
That depends on where you measure it. Internally, on the outflow side of the pump it's pretty close to 3000 psi. It's probably just a few psi lower just before the spray nozzle. After it leaves the nozzle it has zero psi, but it has a LOT of velocity. The actual velocity depends mostly on the nozzle, but that too drops to zero if you measure it far enough away from the nozzle.
3/29/2010 5:13:01 PM •
Mi T M...
Answered
on Mar 29, 2010
