Question about Mi T M WP-3000-4MHB Pressure Washer
How much psi does a 3000psi power wash have when in use
Posted by jameskohli78 on
Al Kupchella
  • 843 Answers
James, That depends on where you measure it. Internally, on the outflow side of the pump it's pretty close to 3000 psi. It's probably just a few psi lower just before the spray nozzle. After it leaves the nozzle it has zero psi, but it has a LOT of velocity. The actual velocity depends mostly on the nozzle, but that too drops to zero if you measure it far enough away from the nozzle.
Posted on Mar 29, 2010
How can i adjust the pressure
Cannot. Ensure u have a 3000psi wand.
Jan 15, 2016 | Northstar Pressure Washer 3000 PSI
Will not pump above 3000psi?
probably has a relief valve in the pump head that prevents over pressure from damaging the pump
3000 psi is extreme for a pressure washer and will remove paint from a vehicle , blow out gaskets on engines , remove cement surface , peel timber surfaces
Sep 08, 2015 | Comet TW 5050 S - Pressure Washer...
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
Washer not working properly
the unloader is bad if not replaced it will damage the packings in the head of the pump go to the car wash an ask them were they buy there rebuild kits and parts they will now
Mar 15, 2010 | Garden
Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Sep 07, 2009 | Karcher 2500 PSI Pressure Washer
What type of oil is best for the 3000psi Honda power washer?
a 30 weight nondetergent oil is recommended, available at any auto parts store.
Aug 05, 2009 | Honda Pressure Washer PSI 3000
I have a craftsman 3000psi power washer. Hose beats the ground
Hi, when the hose shakes badly it is normal down to dirt in the valves.
please check them first
Jul 16, 2009 | Karcher 2500 PSI Pressure Washer
I have a craftsman 3000psi and it keeps losing pressure
hi there,
this means no water pressure coming
to pressure tank it was consumed when use for cleaning, the water pump does not work,check water pump if function,if there over load reset,or had to jumper the connection of pressure switch.
jump the connection of pressure switch,by passing pressure switch if the motor run just jug for 3 seconds,if run you have defefctive pressure switch,replace pressure switch.have a nice day and rate me if your satisfied to my solution,thank's
Apr 30, 2009 | Karcher 1750 psi Electric Pressure Washer
Mi T M WP-3000-4MHB Pressure Washer Logo
114 people viewed this question
Top Mi T M Garden Experts
JOHN LAPIER
dannydoesita
jeff chenault
jeff chenault
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
