20 Most Recent
Mi T M Mi-T-M WP-2403-3MHB NA 2400 PSI 5.5 HP Honda Engine Pressure Washer WP-2403-3MHB Questions & Answers
Pull starting rope Broke
Most recoil assemblies are easy to fix...but not in an obvious way. Remove the recoil asembly from the small engine housing/flywheel cover. Usually three bolts hold it on. 10mm on Honda's. Pull the remaining rope thru the exit hole if possible. Otherwise, fish remaining rope thru the hole by turning rope winding pulley as if pulling handle was still attached, lining up any remaining rope end and pushing thru the exit hole in outer recoil housing or backing it out the inside pulley. Continue to wind rope winding pulley in a counterclockwise ( facing pulley...not outer metal) untill it will not tighten any further. Remove any more old rope. Line up pulley hole and exit hole. Melt end of new rope into a tapered shape..if not supplied that way. the pulley can be held in place by inserting a screwdriver thru the both the pulley and the metal housing spokes. Thread the new rope thru the exit and pulley hole. Tie the rope end sticking thru and draw tight. Cut 6 feet of rope...if not using a presized pull. Release screwdriver from spokes and rope should draw up onto the pulley. Tie off opposite end of the rope to keep from losing that end into the exit hole. put the handle on the rope and tie a knot in the end to retain the handle. Untie the tie-off and allow the handle to fully retract. If handle does not fully retract you may shorten the rope so that it does...as long as you have plenty of pull lenght
How do I replace pull starter rope?
remove the pulley housing cover.Remove the remaining rope pay attention as how its' threaded.Loop the new rope exactly as the old one.That's it
Unit running fine and it
if the motor cuts out, it is electrical, if the pump cuts out it may need a bypass unloader, or valves. If it has a soap valve, make sure it is closed because you may be sucking air
