SOURCE: GE Profile JE1660GB01 magnetron failure?
It pass the resistance tests and still be bad, and I suspect it is.
I would also suggest that you check the high voltage diode to be sure it's not shorted.
If the filament voltage and high voltage are both present at the magnetron terminals, and not loaded down, but there is no heat, then it's the magnetron.
As a pro with over 20 years of expereince, I have always measured the high votlage, but I will never recommend it to a non-professional. Without the right equipment and procedure, you and your equipment can be "fried". No kidding.
Here are some good links to safety & troubleshooting:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
SOURCE: GE microwave replacement magnetron
I also have a HotPoint (GE) Spacesaver Microwave Oven (MWO)that we got at Home Depot about 3 yrs ago. The magnetron quit yesterday and I found out online that this is a common occurance with GE MWO's. I found this string and thought I would attempt to have GE send me a magnetron to replace the defective original part.
I called Customer Relations (1 800-386-1215) and spoke with Nikita. I informed her nicely that I was aware that this is a common problem with GE MWO's and that I am a Union Electrician who would like to perform this repair myself. I simply needed the replacement part. She was very understanding and asked for the model and serial number and after a few minutes she supplied me with an order confirm #.
The part should arrive in a few days via FedEx and we will be back into space age cooking and also our appliances will still match. Thanks to all who posted to this string and clued me in (You have saved me a C note!).
David in Omaha
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
SOURCE: No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
