Cameras Logo
W
William Cairns Posted on Sep 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Pentax K50 menu read eye-fi off and I cannot open it.It also reads in the info position that there is no card fitted. There is a brand new card fitted
Tony Parsons
Level 3:
  • Pentax Master 6,405 Answers
  • Posted on Sep 01, 2017
Tony Parsons
Pentax Master
Level 3:
Answers
6405
Questions
Helped
1652354
Points
20272
Try formatting the card in the camera
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Nov 02, 2007
SOURCE: psp pro duo card
try formatting it on your computer first
use the FAT file system
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jun 14, 2008
SOURCE: 4gb Memory card error
In order to use 4gb memory your camera has to be approve for SDHC use.
If it isn't the most memory you can put into your camera is 2 gb
Anonymous
  • 7 Answers
  • Posted on Dec 12, 2008
SOURCE: card read error
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Anonymous
  • Posted on Jun 04, 2009
SOURCE: I cannot format my brand new memory card in my Kodak Easyshare.
Believe the 4 GB card is too large for this camera and internal camera software was not designed to format or manage so much memory.. try a fast SD under 2 GB.
Anonymous
  • 32 Answers
  • Posted on Jun 08, 2009
SOURCE: card locked
The card has a lock on it which must have been disturbed, just take it out and slide it to unlock.
Eye fi memory cards always reads full
hello try to format with active partition manager v3 (free )
tip
How do I Connect my Non-Wireless Camera to a Wireless Network
<p>Your digital camera can store images via a wireless network uses SD cards for memory storage. Special cards are available from SD Eye-Fi and also under the Lexar brand with Eye-Fi software, rather than just a flash memory, Wi-Fi radio that can connect to a local network and send your photos your computer contains. The SD card requires some special configuration and installation on your computer, but it transfers the files stored by the camera directly to your computer without further intervention. <br /> <p><br /> <p>1. Insert the Eye-Fi card in USB reader that came with it. Connect it to a USB port on your computer. If this is the first time you installed the Eye-Fi, the computer recognizes the new device and install the software and start automatically. If the software was previously installed, it will start automatically. <br /> <p><br /> <p>2. Register a new account or log in with your Eye-Fi account with your email and password. <br /> <p><br /> <p>3. Click the Eye-Fi for a firmware update if the exclamation mark symbol is placed. <br /> <p><br /> <p>4. Select your local network from the Network drop-down list. Enter your password and click "Add a network card." <br /> <p><br /> <p>5. Select "I do not want to set up online photo sharing and now" and click "Next." Some cards do not see this screen. <br /> <p><br /> <p>6. Remove the card when the display "Complete" and insert the card into the camera. <br /> <p><br /> <p>7. Take pictures and look for the wireless transmission on the computer. <br />
on Aug 05, 2011 • Cameras
I have a pentax optio E40 camera. The screen reads card locked and I cant get it open
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try a different card.
Can i download pictures to my computer
Yes you can most certainly can :)
For European markets Nikon include NikonView 6.2, while in certain other markets the new PictureProject software is included, you can set this to automaticly import pictures when the camera is plugged into your computer.
the other options would be to remove the sd card from the camera and use a card reader
or another clever option is an "eye-fi" card, this will automaticly transfer pictures to an account when you are within range of an open wifi network
(see here for more info http://uk.eye.fi/)
I have a brand new PENTAX E70L camera, with SD memory card. i took a few photos on it and then turned it off. Now when i turn the camera on it reads -card requires formatting.I press continue , to format...
Make sure you don't have any pics on the internal memory. To be sure, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert the card and go into the menu and do the format thing again to erase the card and optimize it. Use the menu and not the format option the camera has been giving you.
Memory card is not being read
Here are two suggestions:
1) Make sure the card is properly formatted. If you are sure the card is blank, you can use the Format utility in the Set-up menu to format the card.
2) Make sure the card is not write-protected. If looking at the card with the gold contacts facing you and up, there may be a little tab that can be slid to protect the card. From this angle, you can protect the SD card by sliding the tab down (away from the gold contacts) or unprotect the card by sliding the tab up. Sometimes the tab can get bumped part way between the two positions.
Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
5helpful
Pentax Optio M30 - screen reads CARD LOCKED How do I clear??
the sd card has a lock on it, switch it in the up position. this will take it out of lock. good luck
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
